Collecting info on '05 545i engine noise - BMW Forum - BimmerWerkz.com
Old 04-23-2008, 04:39 PM   #1 (permalink)
Car: 2005 545i Sport, Nav, HUD, CWP
top6491 is an unknown quantity at this point
545 owners, I have a problem and I need to know if any of you are experiencing the same thing. In the morning, cold, my engine sounds perfect, purrs like a kitten. But once I put her in gear and put a load on the drivetrain, I can hear a knock/tick/tapping noise. While it is faint, it stills bothers the heck out of me and the dealers service department, who has tired everything and can find nothing wrong, says the noise is typical for 05 545is. Does anyone else experience this noise, can you try and see if you do? I might be taking action against the dealer depending on your responses, thank you.
top6491 is offline   Reply With Quote
Old 04-24-2008, 04:43 PM   #2 (permalink)
From what you describe it sounds like the typical noise that most V8s in general have. The first M60s all the way up until now have had a slight 'knocking' type of noise.
Old 12-10-2008, 10:04 AM   #3 (permalink)
fleming.jf@verizon.net is on a distinguished road
i have the noise and i put a thread on this site about it. the bmw engineer said that it needed a new engine they put the engine in and called me this am and said the the new engine makes the same noise. if the factory engineer says it is a standard noise in this engine why did they expend the cost to replace it something does not sound correct
fleming.jf@verizon.net is offline   Reply With Quote
E60 545i 2003 Steering noise meditek2 5-Series (E12,E28, E34, E39, E60) 3 10-28-2009 02:58 AM
loud engine noise and check engine light steviebhoy 3-Series (E36) 4 06-04-2004 06:59 AM
'95 engine block info please ihula 1,6,7,8 - Series and Mini Cooper 0 12-04-2003 12:35 AM
engine swap info yellowbird911 1,6,7,8 - Series and Mini Cooper 1 11-30-2003 06:45 AM
E30 to M5 Engine Conversion Info CodyB 3-Series (E21, E30) 3 10-24-2003 06:01 PM
