Codes 1213 and 1222 - BMW Forum - BimmerWerkz.com
Old 03-13-2007, 08:29 PM   #1 (permalink)
camper1159 is on a distinguished road
Codes 1213 and 1222
Codes 1213 and 1222, these are not O2 sensors, but Lambda sensors.
What is the difference?
I reset the system when I replaced the battery.
But they came on again for a few days, and now have disappeared.
Can any of you seasoned pros help a newbie figure out if he has to do anything before emissions inspection?
thanks!
camper1159 is offline   Reply With Quote
Old 03-14-2007, 04:37 PM   #2 (permalink)
528iTdude's Avatar
528iTdude is on a distinguished road
Engine codes?
I cannot find the 1213 code definition, but the other is pasted below:
P1222 Pedal Position Sensor 2 Low Input
Hope this helps. Good luck. JM>
528iTdude is offline   Reply With Quote
Old 03-20-2007, 06:35 PM   #3 (permalink)
tAgC's Avatar
Car: 97 540i
tAgC is on a distinguished road
Send a message via Skype™ to tAgC
This might help http://www.e38.org/e32/bmw%20code%20defaut.pdf
tAgC is offline   Reply With Quote
Old 03-20-2007, 09:38 PM   #4 (permalink)
It's really whacky....
The CHECK ENGINE light went out two days ago, then came on yesterday for about ten minutes (out of two hours of driving), then went out.
Then today, it came on after an hour and stayed on for the rest of the drive (1 hour).
My guess is it will go out for a while tomorrow.
Anyone else see this????
Any ideas where to start?
I'll clean the MAF, check the O2 sensors, check the Eng temp sensor. What else?????
Thanks so much for all your help!
Old 03-23-2007, 07:05 AM   #5 (permalink)
fastshivy's Avatar
Car: 1999 540i
fastshivy is on a distinguished road
What year and model car is this? Is this the same car the moonlight mechanic helped you with? Lamda sensors and O2 sensors are the same thing. Lambda was a term used early on by Volvo and others.
When you drive the car the cel comes on and sets a fault code, after the fault (intermittent problem) clears the cel will turn off after about 25miles.....so you are setting a fault then it ..the computer is clearing the code etc. Not likely that both O2 sensors are bad at once. Something is fouling them out. Oil, stuck injector, a bad MAF and other possibilities seen on the above chart.. My bet is still on the MAF, unfortunately it is an expensive part and without plugging a new one in can be very difficult to diagnose.Hope some of these ideas help.
fastshivy is offline   Reply With Quote
Old 03-25-2007, 01:48 PM   #6 (permalink)
No! That was a 1987 535i.
Different car! 1994 530i. Just bought it cheap (I wonder why!). I am going to do what i can to clean up the little problems it has. The guy I bought it from didn't know squat about cars and was scared by all the lights on the console...So I decided to be daring.
Trans Program (trans shifts fine, I am going to get out there and clean the switch on the shifter)
Check Engine Light on at all times (car runs fine, a reset of the computer system extinguished code 1212, now these come up intermittently.)
Wipers didn't run (now they do, search feature is great!)
Upper rear stoplight inop (now it works, just a loose wire)
Check Engine light now comes and goes, showing codes 1213 and 1222, Lambda sensors. It has now been extinguished for about three days.
How about low voltage? I'm on my way to buy a new battery, the one that's in there is weak and will not hold a charge enough to get a green eye...
Thanks for all your thoughts...
Monday I will be calling the gents in at Moonlight mechanic in NC if it comes on again.
Old 03-25-2007, 03:57 PM   #7 (permalink)
fastshivy's Avatar
Car: 1999 540i
Low voltage is always a good place to start. Glad to see you bought another Bimmer! You may just have bad O2 sensors or bad contacts. Good Luck
Old 04-22-2007, 10:07 PM   #8 (permalink)
sailor24 is on a distinguished road
The best test for your MAF is to unplug it and run for a week. If the car runs the same your MAF is likely dead. You will know the difference when you plug it back in or get a new one. Big difference. Second thing is a connection to dead MAF and transmission issues. When the MAF is not working the tranny gets changed as do other things. Very soft limp mode. I think of it as the sport switch is turned off. Oil Pressures come down things are softened to allow for a slightly rich engine config.
sailor24 is offline   Reply With Quote
