Code reads "cylinder 4 missfire" - BMW Forum - BimmerWerkz.com
Old 06-21-2004, 10:54 PM   #1 (permalink)
Bmw528i is an unknown quantity at this point
Thumbs up
Hello all, this is my first time posting. I just recently bought a 1997 528i and this last week the check engine light came on, so I went to Autozone and had them read the code and it said the cylinder four is missing. I do notice that when I first start the car in the morning that it idles rough (misses) but after it warms up (within a couple of minutes) it stops missing. It only misses on start up and then smoothens out. There was one time that it was really cold in the morning and it missed all the way to work. But that was just once. I just recently replaced the spark plugs with Bosch Platinum plus fours but besides that and an oil change I have done nothing to the car. I have no maintanence records so I don't know when the last tune up was done.
If anyone could give me some advice with my troubles then I would greatly appreciate it.
Thank you,
Kevin
Bmw528i is offline   Reply With Quote
Old 06-21-2004, 11:25 PM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
I know that this will sound dumb, but the best solution is to take it to a certified bmw dealer... unless of course you are a mechanic yourself and want to just chop the thing apart and see whats wrong.
Old 06-22-2004, 12:42 AM   #3 (permalink)
silverlea is an unknown quantity at this point
If the new plugs havent fixed the problem,then it is quite possibly one of the sparkplug leads failing. Try throwing in a complete new set.Often a faulty lead will miss when cold,then come rite once car is warmed to running temperature.
Hope this helps.
Silverlea.
silverlea is offline   Reply With Quote
Old 06-22-2004, 09:19 PM   #4 (permalink)
torque, I am kind of a mechanic so I could take it apart if I wanted, But I don't want to if I don't have to and I'm not quite familiar with the whole BMW thing yet.
Silverlea, Sounds like a possible solution because I notice the car doesn't blow any white smoke so the head gasket is fine, the only other solutions are that I have a bad valve, a bad injector or bad spark plug lead.
Thanks everyone for their replies, any more input feel free
Kevin
Old 06-23-2004, 08:25 PM   #5 (permalink)
kowached is an unknown quantity at this point
Kevin, many including myself have had VERY bad experiences with those plugs, below are some examples. Best of luck.
Spark Plugs - Inspection II
OE stock Bosch or NGK, NOT Bosch +4's
There has been more than person that has discovered that their Bosch +4's have "backed out" or worse yet that some or all of the electrodes were actually missing from the plug. I myself found Bosch +4's finger tight after 10,000 miles and I know I torqued them to spec.
http://bimmer.roadfly.org/bmw/forums/e39/f...?postid=3031210
Message Title: Still no fix yet. My valve covers are leaking and
Posted by: Saman on 2003-04-14 at 14:17:53
(posted from: Host: IP: 159.178.203.36)
Message: couple of the spark plugs were drenched in oil. By the way, the Platinum 4 all 8 of them the tiny electrode had dissapeared completely, like it had vaporized. Put a set of the Bosch coppers from the dealership and the car is not missing any more. However, the power is not like what it used to be. I've gotten a catalytic efficiency a code a couple of times. I am thinking that, I might have
messed up the cats by dumping fuel in them when the car was missing for some time. Once I get the valve cover fixed tomorrow. I'm chaning out the O2 sensors since they are stock and the car has 110K and see what happens.
http://bimmer.roadfly.org/bmw/forums/e39/a...p?postid=223607
Message Title: My bad 540i weird idle solved
Posted by: Mike on 2001-12-14 at 13:00:06
(posted from: Host: wwwgate32.motorola.com IP: 136.182.2.222)
Message: Hi All, just wanted to send this warning out. I had the same weird idle problem as Ken S. and used some techroline to get rid of it. But it didn't. I took it to BMW and they said no codes set customer using BOSCH platinum +4, not recommended. Bosch recommended them when I put them in but just to see I put the old plugs back in and it doesn't miss a beat. Thought all of you would like to know not to buy these plugs.
http://bimmer.roadfly.org/bmw/forums/e39/a...p?postid=237174
Message Title: Re: My 97 540/6 is same. Sometimes nearly stalls at
Posted by: Mike on 2001-12-19 at 09:48:11
(posted from: Host: wwwgate35.motorola.com IP: 136.182.2.225)
Message: I complained to my dealer, they check the codes, none and told me to get the Bosch Plat +4 out, no recommended. Replaced them with the Bosch as F7 LDCR and my small idle problem is gone. I have a 98 540i 6 speed, hope this helps.
Later,
Dave
E39 - 1998 540iA Sport (11/97 Production)
E30 - 1989 M3 (44k miles)
1979 Triumph TR7, still have my first car ;-)
Past cars:
E21 - 1980 320i (sold at 130k)
E23 - 1986 735i
I am a BMW Car Club of America member, are you? <a href='http://www.bmwcca.org/' target='_blank'>http://www.bmwcca.org/</a>
<img src='http://members.roadfly.com/kowached/bmwcca1.gif' border='0' alt='user posted image'>
kowached is offline   Reply With Quote
Old 06-25-2004, 01:53 PM   #6 (permalink)
OH that sounds bad, except luckily it had this idle problem before I put in the +4's so I know it's not related to that, but I will keep my eye on that. I purchased new leads and a new development in problems happened. I smell coolant, and when I accelerate fairly hard when it's still cold I see a lot of smoke "poof out of the back of the car" Still trying to figure out wether the smoke is more blue or white, seems white because it evaporates quick into the air and doesn't linger. This also tells me that I may have a bad head gasket...DOH!!!
Kevin
E30 Anti-theft Radio Code aaronhoy 3-Series (E21, E30) 4 06-08-2009 11:40 AM
Strange Fault Code ben_t 5-Series (E12,E28, E34, E39, E60) 0 04-02-2005 06:53 AM
Dwa/ews Input Peake Fault Code? jday 5-Series (E12,E28, E34, E39, E60) 8 02-04-2005 09:19 AM
Asking For Code jshearer Audio and Electronics 1 12-18-2004 08:28 PM
stereo/radio anti-theft code xristo 3-Series (E21, E30) 3 03-02-2004 04:18 PM
