Code 1231 Dmemain Relay/battery Problem - BMW Forum - BimmerWerkz.com
post #1 of 2 (permalink) Old 01-25-2005, 04:58 PM Thread Starter
netrubicon is an unknown quantity at this point
Ive had a new 92 525 for a few months now. Im trying to work out the bugs at this point. Ive been reading as much as possible about my car. I am not a mechanic but have been doing some of the easy stuff.
My check engine light has been coming on, actually flashing eradically for about 2 weeks now. I have an instrument cluster problem as well,(needles going haywire till car warms up). I have the capacitors and will solder them in tomarrow. I also bought a differential speed sensor from autoparts.com and that is going in saturday. My headlights and odometer display dimms a lot as if power is running poorly thru the system. (I am replacing the voltage regulator on the alternator saturday as well). The problem I have now is a 1231 check engine code that says"Battery/ DME main relay",
well my battery is new and I just changed the DME main relay part 12631729004 and the fuel pump relay part 12621735424. My highbeams and foglights dont work, (checked lkm solder ect.), and im getting the trans program message after driving for about an hour. Any thoughts on this would be greatly appreciated.
P.s. I just put snow tires on her. (NOKIAN RSI) MAN ARE THESE GREAT SNOW TIRES!!
Net-
netrubicon is offline
post #2 of 2 (permalink) Old 01-25-2005, 07:13 PM
nigelmansel is an unknown quantity at this point
The erattic electrical problems could be a lack of ground. When the ground is not right ,strange things like this can happen.. I suggest you check all of your ground wires. From battery to frame. Frame to engine. Engine to battery. All of these things need substantial ground to operate correctly. You said snow tires so perhaps these grounding straps are just rusted or need to be cleaned where they connect. Good Luck 2005 525i
Net-
[snapback]279082[/snapback]
nigelmansel is offline
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 1 04-01-2017 04:54 PM
E30 Anti-theft Radio Code aaronhoy 3-Series (E21, E30) 4 06-08-2009 11:40 AM
Engine Code P1421 Problem UsedRomance3 3-Series (E36) 4 10-23-2004 06:20 AM
business cd problem Derlin Audio and Electronics 3 04-23-2004 11:35 PM
