Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 08-16-2008, 05:27 PM   #1 (permalink)
Photos: 0
DDavis2511 is on a distinguished road
Clutch Questions
My clutch went out in my 92 525i. I bought the whole new clutch kit from sachs and i am trying to get prepared before i begin. I have help, but i still have some questions for some of the things i am doing alone. First of all I NEED to remove the whole exhaust and heat shields right??? Then take off the driveline right???
Some help/advise would be nice....
DDavis2511 is offline   Reply With Quote
Old 08-16-2008, 06:24 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 99 C43 AMG, 89 300SEL
Photos: 0
Send a message via Yahoo to darkhorse737 Send a message via Skype™ to darkhorse737
RIGHT... and make sure you have adequate working space between the floor and the car. =)
ay sino caddi ububblaem? Heaven won't take me; and Hell just knows I'll take over...!
Old 08-17-2008, 05:23 PM   #3 (permalink)
Photos: 0
ok so i got the exhaust off and the heat shields. Now I'm at the drive line, and i was wondering how i should attack it?
Old 08-18-2008, 06:13 PM   #4 (permalink)
Photos: 0
Wink
just remove all the bolts that are holding it in place... make sure you prop it correctly or have an assistant hold it up... otherwise, it will fall on your face...
Old 08-19-2008, 04:31 PM   #5 (permalink)
Photos: 0
i have a 3/8 impact wrench but i cant get them off!!!!!!!!!!!!!!!!!!!!!!!!!
help!!!!!!
Old 08-19-2008, 09:34 PM   #6 (permalink)
Photos: 0
Arrow
help!!!!!!
are you using a wrench on the bolt to hold it in place?.. u should.
sometimes, an impact wrench isn't good enough. a breaker bar is a better choice of a dismantling tool (impact tools look sleek bt nothing beats "armstrong")
for the bolts holding the center support... spray them with WD40 or suitable lubricant and leave overnight. they should come off easy the nxt mrng
Old 08-20-2008, 11:23 AM   #7 (permalink)
Photos: 0
ok so i got the driveline off, now should i begin by draining the transmission then? then??
Old 08-20-2008, 04:30 PM   #8 (permalink)
Photos: 0
Arrow
nope, you do not need to drain the tranny.
disconnect battery, disconnect any electrical wire attached to tranny.
detach the shifter
disconnect clutch linkage of slave cylinder(if needed); and then figure the bolts on the bell housing that need to be removed so u can drop the tranny. Make sure the tranny is properly supported when u do this.
(I'm not sure, but starter may need to be moved aside also...)
When bolts are out, rock the tranny slowly backwards until it separates from the engine.
Old 08-20-2008, 07:12 PM   #9 (permalink)
Photos: 0
I disconnected the electrical wiring and found where the shifter, but its on top of the tranny and i cant see how to disconnect it, also will a floor jack be suitible for securing and droping the tranny?
Old 08-20-2008, 07:19 PM   #10 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Photos: 0
Only if you're REALLY good at balancing...
1995 E38 740iL. Highly modded. Faster than you.
Lindsay fan club member.
Old 08-21-2008, 01:52 PM   #11 (permalink)
Photos: 0
where and how do i detach the shifter
Old 08-23-2008, 10:50 AM   #12 (permalink)
Photos: 0
Wink
take out the shifter boot from the console, and it should expose the shift stick retainers
Old 08-23-2008, 02:07 PM   #13 (permalink)
Photos: 0
I got all the bolts out of the bell housing, and got it loose, but now i'm just waiting for some manual help to get it all the way out.
Old 08-23-2008, 02:36 PM   #14 (permalink)
cloud1974's Avatar
Car: 1994 530i
Photos: 0
cloud1974 is on a distinguished road
just curious, were you planning on installing a new throwout bearing and fork as well. and since you have the tranny out, might as well replace the front seal on the block as well so you dont have to go through all that hassle again when it goes.
also how much was yer clutch kit.
i got mine for my 94 530 for under $277, the site i use your kit there would be $225 and free shipping. check em out next time you need parts, and yes its a sachs OEM clucth kit to. Your Parts Search Returned 1 Part(s)
cloud1974 is offline   Reply With Quote
Old 08-23-2008, 02:37 PM   #15 (permalink)
cloud1974's Avatar
Car: 1994 530i
Photos: 0
oops meant rear main seal.
vB code is On
Clutch crazy91318 3-Series (E21, E30) 6 05-23-2005 01:34 PM
Clutch...... bimmerboy328i 3-Series (E36) 13 09-10-2004 04:52 PM
Is my clutch gone? Autotechnica 3-Series (E36) 5 05-18-2004 10:50 PM
Clutch Stop Questions Chriso 3-Series (E36) 0 12-31-1969 07:00 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
