Climate Control Blower - BMW Forum - BimmerWerkz.com
Old 08-09-2005, 08:49 AM   #1 (permalink)
paplip is an unknown quantity at this point
Two weeks ago I got in my '98 528 and the blower for the automatic climate control would not turn. The fan speed was all the way to the max but no air. It was really hot in the car so I got home with the windows down. Looked around quickly and decide to look at it later.
In the evening when I got in the car, everything was working normally.
Now I got the same experience yesterday, blower off then (few hours later) everything gets back to normal. Even if I turn it off or adjust the fan speed manually, nothing seems to be working until the car has cooled down.
Both times, the car was in the sun in a high temperature day.
Has anyone ever experienced that problem? Could it be a fuse or is there a sensor somewhere?
Thanks
paplip is offline   Reply With Quote
Old 08-09-2005, 04:19 PM   #2 (permalink)
ErikB is an unknown quantity at this point
I had the same problem on my '02 530i. I took it to the dealer (under warranty) and they had to replace a relay or sensor or something in the blower (sorry I can't remember which part it was). Since I got it back -- no issues.
ErikB is offline   Reply With Quote
Old 08-10-2005, 03:20 AM   #3 (permalink)
Is the blower speed ever erratic? I mean... does it come on full blast when it shouldn't be or anything like that?
If so, it could be the final stage unit. It's a fairly common problem.
Old 08-10-2005, 09:40 AM   #4 (permalink)
No, aside from those two occurences, it is working just normal. I was also thinking about a kind of relay that would fail when too hot.
Old 08-10-2005, 01:32 PM   #5 (permalink)
Look what I found on the Bavauto site called "Blower resistor for car with automatic air conditioning". There is a big heat sink on top of it. My guess is that this is what is causing the problem.
Anybody ever bought one of those and would know where it goes?
Old 08-10-2005, 09:14 PM   #6 (permalink)
nathan56989 is an unknown quantity at this point
The final stage resistor will make it do those syptoms it does not just make it blow sporadically. just tell the dealer you want the final stage replaced becasue the ac is not working.
nathan56989 is offline   Reply With Quote
Old 08-11-2005, 10:39 PM   #7 (permalink)
Steve530 is an unknown quantity at this point
Thanks
[snapback]368467[/snapback]
Classic symptoms of the FSU failure.
The part is about $75.
It's located on the left side of the passenger footwell.
Steve530 is offline   Reply With Quote
climate control fan speed sanga 5-Series (E12,E28, E34, E39, E60) 4 06-02-2010 11:47 AM
BMW has perhaps the WORST climate control SpeedsterBMW 3-Series (E46, E90) 27 05-03-2010 09:59 AM
Rebuilding your e36 climate control computer 98e36bostonchic OEM Parts 2 10-18-2005 09:09 AM
Climate Control Unit mmclaren 3-Series (E36) 2 06-20-2005 07:33 AM
Climate Control Rookie 3-Series (E36) 9 03-14-2005 11:51 AM
