"Check Engine Soon" displayed - BMW Forum - BimmerWerkz.com
Old 06-29-2006, 08:04 AM   #1 (permalink)
cweeks is on a distinguished road
2001 540I with 45K miles on it. Just got this "check engine soon" display. I am thinking this is a data link reset procedure to get rid of this annoyance??? Or is this a diagnostic that indicates something is amiss with the emissions stuff???
Should I ( and if so how) reset this warning???
cweeks is offline   Reply With Quote
Old 06-30-2006, 01:52 AM   #2 (permalink)
CosmosBlack's Avatar
Car: 2002 Porsche C4S
You should get it read/checked to see what is wrong.
Defeats the purpose to just reset it, doesn't it?
Old 06-30-2006, 07:10 AM   #3 (permalink)
not sure how the software is designed--it could be that at routine intervals they post the message so you take the car back to the stealer.
Old 06-30-2006, 09:11 AM   #4 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
No, that's not the case!
There is a tool you can buy that reads the codes or take it to an autoparts store where they'll check it for you. It could be many things but this is for sure emissions related.
Did you overfilled the gas tank? check the gas cap? How's the car running?
LOS
Old 06-30-2006, 12:19 PM   #5 (permalink)
Car: BMW 2003 525i
Alex MPower is on a distinguished road
Send a message via AIM to Alex MPower
Los is right! Check the gas cap,when you close it you should hear a clic! My dad had this problem on his 2002 Toyota Rav4,and after closing the cap to first clic it worked!
Alex MPower is offline   Reply With Quote
Old 06-30-2006, 01:41 PM   #6 (permalink)
Eric S.'s Avatar
Eric S. is on a distinguished road
Go to Autozone; they have a reader they will either use themselves or loan you for free that can read the OBD-II codes that has been triggered. This will give you a clue as to what's wrong. Once you've fixed what's wrong, you will need the dealer or a Peake type of tool to reset the code so your CEL turns off. There is also a way to do it without a tool, via jumping certain terminals on your diagnostic port, but it is rather risky to do and you can potentially screw up your ECM if you don't do it right.
<span style='colorurple'>Eric S.</span>
2006 Honda Odyssey EXL-RES
Eric S. is offline   Reply With Quote
Old 06-30-2006, 02:35 PM   #7 (permalink)
LYFE SUCK5
Ivan's Avatar
Car: 2008 Infiniti G35
Ivan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant futureIvan has a brilliant future
Send a message via AIM to Ivan
yeah check engine lights come on only for emissions related stuff
Ivan is offline   Reply With Quote
Old 06-30-2006, 08:42 PM   #8 (permalink)
Moderator
Dirty_Tool's Avatar
Jumping pins at the diagnostic connector will not clear a check engine or SES lamp. There are 2 pins at the diag connector you can jump for resetting the oil service or Inspection lights, but as Eric said, you risk causing damage to the Instrument cluster.
DT
DT
Old 06-30-2006, 10:28 PM   #9 (permalink)
Eric S.'s Avatar
Thumbs up Thanks DT!
DT
Sorry, thanks for the correction, DT. You are tha man.
Now if only you could tell me why my A/C compressor is rattling loudly, yet still cools the car wonderfully.
Old 06-30-2006, 10:37 PM   #10 (permalink)
Moderator
Dirty_Tool's Avatar
Eric,
Make sure its not just the belt tensioner making noise and that its actually coming from the compressor. If it is there are products like BG's Frigi-quiet that you can add to the AC system to possibly quiet it down some. I just wouldnt buy a cheap auto-zone product, Id search online for either the BG stuff or similar professional grade additive.
DT
DT
Old 07-02-2006, 06:55 AM   #11 (permalink)
DT
thanks for the response. Im an electrical guy so if you can tell me what pins need to be handled at the obd2 diag port it would help me when i do my oil changes. ive ordered a obd2 reader just to be sure. i really think the problem was the gas cap as the light has extinguished without any intervention other than normal gas fill ups.
Old 07-02-2006, 12:24 PM   #12 (permalink)
Moderator
Dirty_Tool's Avatar
This is for 01 and later if you do NOT have the 20 pin round diagnostic connector under the hood
BMW insp. reset
- Iginition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
Note: Instructions courtesy of www.bmwtips.com
DT
Old 07-03-2006, 01:41 AM   #13 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Well, not quite. My camshaft position sensor threw a CEL fault code too.
Lindsay fan club member.
Old 07-03-2006, 07:02 AM   #14 (permalink)
DT-
Many thanks for the link. Just what I was looking for. What does "HIGH" cluster mean??? Higher vin's have different clusters???
Old 07-03-2006, 11:52 PM   #15 (permalink)
Moderator
Dirty_Tool's Avatar
The "High" cluster is a higher line cluster with the matrix display which will give you warnings etc via text. A low cluster will have a pictogram of a car on it to show you warnings like "door open" or "tail light out" Most 540i's will have the high cluster while the 528i's will have the low cluster. The exception would be any 528i or any e39 for that matter with Navigation will definitley have a "high" cluster.
DT
DT
Desperately Need Your Help: BMW325i "Service Engine Soon" light problem CNMB250 3-Series (E46, E90) 4 12-19-2007 06:26 AM
