Ok, so its on...AGAIN ghead I've already replaced my gas cap...Does anyone have a list of what can cause the "Check Engine" light to come on?
Thanks in advance,
NEW POST 11/15
Well, $#!&! The light is back on again and this time its been 4 days without going out. It lit up on a really rainy day (like the first time) does this hint to something in particular being wrong.
Originally posted by ///Matt@Nov 4 2004, 08:04 AM Ok, so its on...AGAIN ghead I've already replaced my gas cap...Does anyone have a list of what can cause the "Check Engine" light to come on?
Thanks in advance,
[snapback]224281[/snapback]
my 328 has been having the light come on, then after a few days it shuts off again, it happend twice like that, its off now.. just ride it out for a week or two
if it really want, go to autozone, they will read it for you..
__________________ *If your not living on the edge your taking up too much space*
///MAT: Does anyone have a list of what can cause the "Check Engine" light to come on?
If I give you the list, are you willing to spend your money on every possible code in the list? I think your best bet is A. a code reader/scanner for about $135-$145 and/or scan it for free.
regards
billb
Go to AutoZone and they will scan it for you for free. It will tell you exactly whats wrong.
Does it only come up on rainy days? Here is a long shot: When I went to get my brakes done to the dealer, they told me that I was missing a panel that goes inside the front fender (where your strut is ), on the pasanger's side. The guy said that there is a little pump there when it gets wet, my check engine light will come up. Once it goes bad, its like 700 bucks for a part.
I experienced a simular problem with my 98" 540I. I took it to the dealer three times. Every time after about 3 to 5 days the check engine light would come back on. They ran the codes several times, and could not resolve the problem. However, upon an indept engine inspection a service tech noted some stressed knocksensor/spark plug wiring. He also noted that someone had performed some cylinder head work on the vehicle in the past. He suggested that is what probably created the wiring stress and causing the problem. He repaired them and I have not had the problem since.
Fruthermore, my check engine light comes on whenever my wife attempts to SAVE MONEY and burns 87 octane gas in our 328I. I immediately go to sunoco and fill it up with 94 and the light goes away.
