Check Engine Light On - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 10-24-2004, 06:29 PM Thread Starter
fly gti's Avatar
fly gti is an unknown quantity at this point
I got check engine light on. It is a 2000 528I. Car has 47000 miles and it is automatic. The light came on 3 or 4 times. I have the bavarian fault code reader and when i ran it gave me codes 15 and 41. The booklet gives me few 15s and 41s. Here they are 15:
- precat oxygen sensor response time cyl# 5-8
- precat oxygen sensor slow response cyl# 5-8
- exhaust camshaft VANOSretard valvecyl#1-4
- VANOS (solenoid)
- VANOS solenoid intake
41s:
- camshaftsensor
- misfire detected catalyst damaging cyl# 3
- thorottle position sensor 2, slave movment
- A/C compressor
I deleted those codes but after a week or so it comes back. When it does car has a hesitation during acceleration, and starts hard which means it doesn't start right away takes a bit more time.
Did it happen to anyone of You. All comments are welcome
fly gti is offline
post #2 of 6 (permalink) Old 10-24-2004, 06:39 PM
billB's Avatar
billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute
FLY GTI
I would double check these fault codes because they seem very wrong unless you have installed an 8 cylinder in your car!
While you do have 2 precat O2 sensors and 2 postcats. That is a total of 4 sensors; they only deal with cyl # 1-6 NOT cyl # 1-8 unless you were looking the codes up in the 540 table!! Double check on the above since you have a 528i (6 cyl not 8) and let us know.
Hint: Try to look up the same codes in table 11 instead of 15
regards
billb
billB is offline
post #3 of 6 (permalink) Old 10-24-2004, 06:51 PM Thread Starter
fly gti's Avatar
Originally posted by billB@Oct 24 2004, 04:39 PM
FLY GTI
regards
billb
[snapback]217592[/snapback]
You are right i am just not sure which chart should i reade them of. I just gave all possible answers, and the car has 6 cyl.
fly gti is offline
post #4 of 6 (permalink) Old 10-24-2004, 07:38 PM
billB's Avatar
FLY GTI
This is more like it. So when you plug in your code reader and press GO usually the 1st number that pops up is your reference to the table number in your book. Once done and since you have many codes (serious ones if I may add) write it down then cross reference it with the table and repost.
good luck
regards
billb
billB is offline
post #5 of 6 (permalink) Old 10-24-2004, 09:33 PM Thread Starter
fly gti's Avatar
Originally posted by billB@Oct 24 2004, 05:38 PM
FLY GTI
good luck
regards
billb
[snapback]217668[/snapback]
ok this is what it looks like first #15 then 4, so that means that I have to go to to chart 15 and look for a code 41 right? If that is the case the reading sayscamshaft sensor intake cam
fly gti is offline
post #6 of 6 (permalink) Old 10-24-2004, 09:47 PM Thread Starter
fly gti's Avatar
Originally posted by fly gti+Oct 24 2004, 07:33 PM--><div class='quotetop'>QUOTE(fly gti @ Oct 24 2004, 07:33 PM)</div><div class='quotemain'><!--QuoteBegin-billB@Oct 24 2004, 05:38 PM
FLY GTI
good luck
regards
billb
[snapback]217733[/snapback]
[/b][/quote]
So that means that the sensor needs to be replaced, did anyone of you did it before? If you did how hard is it to change it?
fly gti is offline
Check Engine Light came on today camnipotent 3-Series (E36) 24 08-08-2014 06:20 AM
Check Engine Light aheath 3-Series (E36) 1 04-27-2005 07:27 PM
Check Engine Light On, But Only When I Start Car BMW-ATI 3-Series (E36) 5 04-15-2005 10:40 PM
Check Engine Light & Air Bar Light blackstallion 3-Series (E36) 1 11-11-2004 12:53 PM
Red check engine light came on today YNGRVP 3-Series (E36) 9 05-28-2004 10:36 PM
