Hi guys - wondering if someone can help.
I've a '89 525i E34 with a few dahboard instrument problems. Matrix display/odometer/trip meter are completely dead, although ABS/oil pressure/handbrake etc warning lights are OK. Tacho and speedo are fine, but fuel and temp gauges recently started misbehaving as well.
While driving, would suddenly hear the warning ping and fuel/temp and 'energy control' guages would flick on and off. This would happen a number of times and the wouls stop - either with the gauges working - or not working. Next time i drove it would happen again, or not, totally ay random. As matrix display is not working, can't read of any particular problem. (Mannually checked all fluid levels and for leaks etc - all good.)
Found and fitted a secondhand instrument cluster with a perfect matrix display and all was good for a couple days until it suddenly started pinging and cycling through all the warnings (including some i know aren't applicable to my car) eg >catalyst>bonnet open>door open>brake light circuit>consult user manual>FR tyre pressure>FL tyre pressure etc etc.
Checked all levels again and everything appears OK.
This pinging would start a few minutes after starting car - go for 5-10 minutes then stop - but the warnings keep scrolling in the display.
The pinging was driving me crazy so i took out the cluster and returned my old faulty one. (NB my pinger DOES work when i exceed speed limit, have low washer fluid level etc)
i sent pics of my old unit and dealer went to pains to make sure they sent the matching one.
Any ideas? would the new instrument cluster be faulty? Where? Is there some sort of master control giving wrong readings? Perhaps OBC? Suggested resolution of my problem?
i have trawled through this forum and found lots of threads about instrument/check control issues, but none quite like this.
This is the first i have ever heard of this. If its doing it with two different clusters then its not the cluster. Its something electronic. Possibly a wiring issue or a sensor issue.
