"check Brake Lininings"????? - BMW Forum - BimmerWerkz.com
Old 05-07-2005, 11:09 AM   #1 (permalink)
vlad_ignatenko is an unknown quantity at this point
Does anyone know what this message is?? My obc recently started to show
"check brake linings" What is that supposed to mean? ghead
If anyone knows please tell me...
vlad_ignatenko is offline   Reply With Quote
Old 05-07-2005, 11:26 AM   #2 (permalink)
it means it's time to replace your brake pads. It's just an electronic warning rather than the squeal that most other cars put off. No big deal, no big expense.
Old 05-07-2005, 01:02 PM   #3 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
front left and right rear wheel have brake sensors. a wire with a plastic block at the end. when your brakes get low enough, they chew through the plastic and give u the warning. u need to replace the brake pads and the sensors (they are cheap)
after that is done, put your key in position 2 (on, but not running) and leave it for a minute to clear the warning.
Old 05-07-2005, 03:24 PM   #4 (permalink)
NESS is an unknown quantity at this point
I had a guy recently turn my rotors and he said this sensor cable broke or something. So now the 'check brake lining' red symbol shows up all the time. He looked at my pads and told me they were fine. Where do I get this cable or sensor that goes by the brake, just from a dealer? And can someone point me to a DIY for it.
NESS is offline   Reply With Quote
Old 05-07-2005, 08:19 PM   #5 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
[snapback]341947[/snapback]
Either dealer or your local AutoZone/PepBoyz,... price should be around same.
Installation is easy... when u go to do it, you'll see... there is really no instructions needed. it's a wire...
Old 05-07-2005, 09:01 PM   #6 (permalink)
bimmerjac is an unknown quantity at this point
Originally posted by Torque+May 7 2005, 09:49 PM--><div class='quotetop'>QUOTE(Torque @ May 7 2005, 09:49 PM)</div><div class='quotemain'><!--QuoteBegin-NESS@May 7 2005, 04:24 PM
I had a guy recently turn my rotors and he said this sensor cable broke or something.* So now the 'check brake lining' red symbol shows up all the time.* He looked at my pads and told me they were fine.* Where do I get this cable or sensor that goes by the brake, just from a dealer?* And can someone point me to a DIY for it.
[snapback]342023[/snapback]
[/b][/quote]
bimmerjac is offline   Reply With Quote
Old 05-07-2005, 09:10 PM   #7 (permalink)
I would not recommend turning rotors or just putting pads on...... It will cause problems. When a BMW needs brakes you should replace pads, pins, rotors and sensors. A DIY'er can do the job for about $500 - $600 for front and back.
Sorry for the repeat post... Did it by accident
Old 05-07-2005, 10:06 PM   #8 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
[snapback]342036[/snapback]
Am I understanding you correctly ? You suggest we all recommend the rotors every time the pads are worn ?
Old 05-07-2005, 11:05 PM   #9 (permalink)
CosmosBlack's Avatar
Car: 2002 Porsche C4S
[snapback]342047[/snapback]
That's what dealers do all the time and those who go to the dealer only, believe that is the case!
From my experience with my independent mechanic, I've needed new rotors 2 out of 3 times...
Old 05-08-2005, 12:47 PM   #10 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Originally posted by CosmosBlack+May 8 2005, 12:05 AM--><div class='quotetop'>QUOTE(CosmosBlack @ May 8 2005, 12:05 AM)</div><div class='quotemain'><!--QuoteBegin-Torque@May 7 2005, 10:06 PM
[snapback]342062[/snapback]
[/b][/quote]
Well, seems to me like you need a new mechanic !
Rotors have a marking -- when they get worn past that point they need replacement. And I will assure you they won't get worn as fast as pads... they'll take quite a few pads to chew through them.
Old 05-08-2005, 02:14 PM   #11 (permalink)
rotors dont only need to be replaced or turned because of the material left.
They don't always wear completely even and often have grooves. When the grooves are present, theres less contact patch from pad to rotor, less braking efficiency, less even-wear, etc etc. It may not be the most important thing, but it's also not OPTIMAL. So we can all assure eachother that the rotor will rarely be worn down to it's minimum, but thats not the point. There are other reasons to replace rotors. They DO often warp, get unusually large gouges, etc. That SHOULD be replaced.
Old 05-09-2005, 12:03 AM   #12 (permalink)
BMW rotors are only good for 2 sets of pads. pretty much only on domestic cars with huge rotors will you be able to get more than a couple set of pads on a set of rotors. it also depends on the quality of the rotors and how agressive the pads are. you can replace only the pads, although not the ideal way to go, as long as the rotor thikness is not near the minimum thikness spec stamped into the rotor. i agree with sp0rky. for the best brake performance the rotors should be perfectly smooth when new pads are installed, for braking performance and maximum life of the pads. but as long as the rotors are not grooved really deep,overheated, or warped the new pads on an unturned rotor should be fine given the thikness of the rotors aren't too close to the spec. one way to tell if it is too close to spec is, if you have only had one set of pads on the rotor, take the actual measurement and subtract it from the original thikness of the rotor and see if that number is at or below the minimum thikness spec. other wise you can run into wapred rotors or overheated rotors. which both can compromise the life of the new pads. overheated rotor will overheat the pads which can casue the car to take more pedal pressure to stop the car or even casue the pads to fall aprat in extreme cases. and warped rotors will chew away at the pads and use more brake material, thus making the pads not alst as long.
oh and BMW doesn't recomend turning the rotors. although it is not impossible nor will it nesecerily be a bad thing but that is just what BMW recomends.
Parking brake not releasing GnarlyCow 3-Series (E46, E90) 13 07-29-2004 03:39 AM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
