Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
» Tire Upgrade Garage
Sponsors
Sponsors
Old 05-08-2008, 11:15 PM   #1 (permalink)
Photos: 0
My Silver 2000 540I is on a distinguished road
Question Check Brake Linings on 2000 BMW 540I
Ok guys -
Here is one for you. I got a 'Check Brake Linings' message on my 540 along with the Brake light being ON this past weekend. I noticed it after I had floored the car to show off...(pretty stupid, I know, gets worse - to my wife), not when I was breaking - go figure!
Car seems to be stopping fine. All four rotors and brake pads were replaced recently, I am sure they are fine. Any suggestions on what to look for and how to fix it? Also, even if I were to fix it, how do I turn off the error message?
As usual, any suggestions and tips would be greatly appreciated!
Thank you in advance!
My Silver 2000 540I is offline   Reply With Quote
Old 05-09-2008, 12:15 AM   #2 (permalink)
Photos: 0
witeshark is a jewel in the roughwiteshark is a jewel in the roughwiteshark is a jewel in the rough
Have the brake wear sensors checked
Sig by zeaq328i
Old 05-09-2008, 06:06 AM   #3 (permalink)
jeraldchrist's Avatar
Car: 99 528i 97 540i
Photos: 0
jeraldchrist is on a distinguished road
brak linings
I am willing to bet that it hit the skid control, which is actually is linked to the abs.Try to disconnect the battery for a minute and let it reset. If it appears again you might have to take it to the man. Then again maybe the brake linings need checked. If it makes you feel any better I pulled the back wheel off of mine about two days after I bought it and the pads were down to the nub, no material left, and nothing from the brake sensor. good luck
Sertafied Rocket Surgeon
jeraldchrist is offline   Reply With Quote
Old 05-09-2008, 07:10 AM   #4 (permalink)
Nick_318is's Avatar
Car: 1991 BMW 318is, 2007 Mazdaspeed3
Photos: 0
Nick_318is is on a distinguished road
Send a message via AIM to Nick_318is
I agree with witey, Sounds like a brake sensor to me, especially if you just had the pads and rotors changed. I currently have a sensor that doesn't fit into my pad up front so I just have it tied off under the car so I won't throw any lights but I check my brakes more then most normal people.
Nick_318is is offline   Reply With Quote
Old 05-09-2008, 07:44 AM   #5 (permalink)
winters97E39's Avatar
Car: 1997 BMW 528i
Photos: 0
winters97E39 has a spectacular aura aboutwinters97E39 has a spectacular aura aboutwinters97E39 has a spectacular aura about
Send a message via ICQ to winters97E39 Send a message via AIM to winters97E39
Yep, I agree too. Try the simple things first, unplug the brake pad sensors, give them a dust off and replace, make sure connections are snug, then have your codes reset, see if it goes away.
Jason / 1997 528i
winters97E39 is offline   Reply With Quote
Old 05-09-2008, 08:52 AM   #6 (permalink)
Photos: 0
Question Thanks! How do I have the codes reset?
Thanks! I was thinking about the brake sensor and will check them - left front and rear right, correct?
Once I do that, how do I get the codes reset? Could I just go to Autozone and ask them to that with their OBD II scans (used to do that with my 99 Passat) or do BMW's have special tools that only the dealers have?
Also, I read somewhere that once the sensor goes off, I need to get a new one (the old one pretty much burns). Does that sound right? If I decide to not connect them (I do check my brakes as well), would that trigger any other 'warning lights'?
Thanks again, folks!
Old 05-09-2008, 08:58 AM   #7 (permalink)
Nick_318is's Avatar
Photos: 0
Yes the sensors should be in the right front and left rear. Autozone should be able to reset codes but I don't know how the older sensors work, on the e30 the light shuts off when you reconnect a fresh sensor.
If the sensor is dead you will probably need to replace but they are cheap. I don't think you will get other warning lights without them but i'm not sure how obd2 deals with that stuff.
Old 05-09-2008, 10:10 AM   #8 (permalink)
drz
master of his domain
drz's Avatar
Car: E36 2.8i
Photos: 0
I think you will get a warning light without the sensors, but I also do believe that the current warning will go away once you plug in the new sensors.
Turkey Fleet Bond Holder
Old 05-11-2008, 08:58 PM   #9 (permalink)
Photos: 0
Question Lights went away and then came back...
Ok, Friday evening I floored the car again and the lights disappeared (both the brake light as well as the massage on the board computer). It seems like one does not need to reset those, just wanted to share with the group.
Sunday, the lights went off again (I have not done any stunts with the car...). That does seems like a bad connection somewhere. I did not get a chance to unplug and plug again the sensors due to the rain here but it seems like something is getting disconnected and then connected again...
If there are any other suggestions, I will make sure to try them as well.
As always - thank you in advance!
Old 05-12-2008, 01:08 AM   #10 (permalink)
Photos: 0
Sensor didnt fit
When I did the brakes on mine a week or so ago the sensor was to small for the cut out provided in the new brake pads. I am willing to bet there is some play between the sensor and the pad, losing contact with it and triggering the warning. It was enough that heat/ expansion might be enough to break the circut.
vB code is On
Hello 540I 2000 abmw2nv 5-Series (E12,E28, E34, E39, E60) 1 03-30-2008 11:54 PM
2000 Bmw 540i 6 Speed Below Book - Loaded WindowPro Classifieds Sell & Buy 1 03-29-2005 10:04 AM
E39 Check Brake Linings Light =\ FaKe_M5 5-Series (E12,E28, E34, E39, E60) 2 01-29-2005 01:23 AM
Check Brake Linings audiosolstice 6,7,8,X,Z - Series and Mini Cooper 1 04-02-2004 11:58 AM
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
SEO by vBSEO 3.1.0
