CHANGED STARTER both starters good Help - BMW Forum - BimmerWerkz.com
Old 12-05-2011, 09:55 PM   #1 (permalink)
joserodrigo is on a distinguished road
I just changed the starter on my 1997 540i 6 speed to find out the problem was not the starter now 300$ dollors later and car still wont start what would be the next option and where to find it gents please come thru ........
joserodrigo is offline   Reply With Quote
Old 12-06-2011, 10:36 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
What are the symptoms?...
Does it just "click"? If yes then it could be a poor earthstrap connection...
Does the starter turn? If yes then it will be one of many other things !
Please give more info ;-)
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 12-08-2011, 08:40 AM   #3 (permalink)
THanks for responding and it clicks once then it nothing.......it use to be click nothing try again ...try again then work.......now just a click HELP PLEASE>>>>>>going nutz mechanics are scared of it .....dont want to throw more money out during christmas...
Old 12-08-2011, 08:48 AM   #4 (permalink)
Okay, this is joserodrigo's wifey. When we try to turn on the BMW it only "CLICKS" once and that's it. So we tried push starting it man-power at first, then again with the help of another car pushing us. NO LUCK. So we took the next step and bought a new starter. NO LUCK. Still clicks. Now what??? What is the "Earthstrap connection???" PLease tell me it's something I just have to connect MYSELF!!! Thank you!! help!!
Old 12-08-2011, 10:48 AM   #5 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
The earthstrap is the fat cable that connects the engine to the body as a "Earth/Ground"...
Now for the "Click", is it a relay click or is it the solenoid on top of the starter that clicks?
If it is a relay click then maybe a wiring fault from relay to starter.
If its a solenoid click then there is not enough power getting to the starter to spin it, again, a wiring fault.
Eso es todo!
BMW Part Market
New Member ?
Old 12-08-2011, 02:27 PM   #6 (permalink)
thank you so much will now go mess with all the grounds........
Old 01-16-2012, 07:43 PM   #7 (permalink)
golfgod's Avatar
Car: 2001 540i and 1997 528i
golfgod is on a distinguished road
Send a message via Yahoo to golfgod
i don't mean to sound silly, but did you check the battery for a loose connection? the starters have a voltage regulator and that can go bad too. the other parts of the car can be on and not pull too much, but then the starter uses a lot more juice...or did you already figure this out? i am curious
2001-540i
golfgod is offline   Reply With Quote
Old 01-21-2012, 02:56 PM   #8 (permalink)
westin is on a distinguished road
try the spare key
westin is offline   Reply With Quote
2006 BMW 330i - Replaced starter and now car not running good jazj10355 3-Series (E46, E90) 6 08-23-2011 12:01 AM
Changed starter and now no spark??????? Landscape 3-Series (E21, E30) 7 05-26-2008 10:40 PM
Changed My Oil Brian325i 3-Series (E36) 1 09-26-2004 08:57 PM
Remote starters BMWChicago 3-Series (E36) 4 12-10-2003 05:39 PM
