| Car ABSing 1999 540 6 Speed.
OK solved one isue now have a new one. Originally ABS and DSC lights on and speedometer not working. ABS module sent in and check/repaired and is good. Replaced the left rear wheel sensor and above problems went away. New problem is ABS activates when stopping at about 1 to 2 MPH. Replaced right rear sensor no change. Scanner come up empty.
Do I continue replacing the front sensors? Did same thing a couple years ago and replaced left front and problem went away. I plan to replace the right front now. Are there any other things that I could look for other than the sensors? |
