| I am trying to remove the sword from my 535i e34 1991. It is a RHD car and the problem occurs as I try to pull out the sword, it hits the sterring column linkage. Hence I can't remove it.
I think this problem occurs as it was designed as a LHD and so removing the sword would be easy.
Has anyone had this problem before and how is it solved without having to disconnect/remove the steering column linkage. |
