A/C button question - BMW Forum - BimmerWerkz.com
Old 05-27-2011, 02:05 AM   #1 (permalink)
6670charger is on a distinguished road
A/C button question
Just a quick question about the A/C button. Mine does not illuminate except for a second or two occasionally right when I start the car. I've never heard the compressor kick in when I press the button, but, I also don't know if the button is bad. I assume that the button acts just like any other switch, in that if illuminated, the circuit should be open, and if not illuminated, the circuit should be closed? Might it be that my switch just doesn't work?
6670charger is offline   Reply With Quote
Old 05-27-2011, 02:20 PM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Relay? or fauly pump...
Just an idea
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 06-06-2011, 06:04 AM   #3 (permalink)
/Banned
Car: 2000 Honda civic
Jhony505 is on a distinguished road
I am not an expert in A/c circuits. May be problem with switch light or A/C clutch engagement wires. Not quite sure, Just my thoughts.
Jhony505 is offline   Reply With Quote
Old 06-25-2011, 10:53 PM   #4 (permalink)
Car: 1995 525i Calypso Red
Pete Lech is on a distinguished road
My AC quit after a month of intermittent operation. I know there was a good charge, as it was cold when it did engage, so I spent several months screwing with the switch, replacing the relay, etc. All three switches on the panel quit working.
It turned out to be a faulty HVAC computer. I put in a used switch panel and voila!, it works perfectly. You can hang meat in the car. The Bentley manual does not even refer to it as such, just as the IKD box (not exactly right, but I don't have access to my records as I am out of town). It is located near the pollen filter in front of the center console in the car.
Pete Lech is offline   Reply With Quote
Old 06-26-2011, 10:49 AM   #5 (permalink)
Well, the problem with mine is that the AC hasn't worked since I bought the car. It could be the computer, the switch, or a host of other things, and probably a combination of them.
I never gets that hot in Germany, so it really doesn't matter that much. I'll only have the car for another 9-10 months anyway and then time to pass it on to someone else.
Old 06-27-2011, 12:22 AM   #6 (permalink)
/Banned
Is that second handed one? It could be anything relay? switch?compressor? need more info.
Ultimate DIY for 18 Button OBC Upgrade from 7 or 11 Button OBC Made Easy w/ Pictures! Delmarco FAQ's and DIY's 33 04-28-2010 01:56 PM
E39 Dash Button Question 540sport 5-Series (E12,E28, E34, E39, E60) 2 04-27-2005 08:59 PM
Will An 18 Button Obc Work Replacing An 11 Button? lulul 3-Series (E36) 5 02-10-2005 11:38 PM
Upgrading 6 Button Obc For The 18 Button One... Delmarco 3-Series (E36) 2 10-04-2004 07:56 PM
Question about the Range button jrhaile 3-Series (E36) 5 06-20-2004 12:05 PM
