buzzing noise from climate control - BMW Forum - BimmerWerkz.com
Old 09-16-2004, 06:10 PM   #1 (permalink)
bmwmoy is an unknown quantity at this point
I have noticed a Buzzing noise from the climate control panel. It even buzzes when the key is taken out. Appears to get louder at higher revs. I have seen this problem ( without solution on the 3 series site)
Anyone else afflicted? Thoughts?
bmwmoy is offline   Reply With Quote
Old 09-16-2004, 08:06 PM   #2 (permalink)
billB's Avatar
TO BMWMOY:
Based on your description and if If I have to guess I would say It's the relay which is buzzing because it does not have enough voltage across its coil to completely do
what have to be done. The act of closing the contacts alters its concept of ground enough to open the contacts which alters its concept of ground again and closes the contacts. Buzzzzzzzzzzzzzzzzz
Have someone check it out for you...let us know
regards
billb
Old 09-17-2004, 12:50 AM   #3 (permalink)
Thanks for your help. I will get it checked out and let you know.
Old 09-18-2004, 02:23 PM   #4 (permalink)
BeelZibub is an unknown quantity at this point
I have noticed a couple of times a buzzing from the climate - sometimes I have even left the car without a buzzing but when I return the next morning it has started. However it never seems to last long and only occurs very infrequently so I haven't bothered with it - 4 months later and she still works fine so I'm not worried.
Let us know if you find the problem though
BeelZibub is offline   Reply With Quote
Old 09-18-2004, 02:39 PM   #5 (permalink)
Things to remember:
1. If you have an "E box in the engine compartment (with EML) there is a fan that activates to keep the "E box components cool, and yes, she runs when key is inserted.
2 The stepper motors may buzz a bit as they re repositioning at start and after shut down.
Old 09-18-2004, 08:39 PM   #6 (permalink)
billB's Avatar
Bear
excellent point
climate control fan speed sanga 5-Series (E12,E28, E34, E39, E60) 4 06-02-2010 11:47 AM
BMW has perhaps the WORST climate control SpeedsterBMW 3-Series (E46, E90) 27 05-03-2010 09:59 AM
Rebuilding your e36 climate control computer 98e36bostonchic OEM Parts 2 10-18-2005 09:09 AM
Climate Control Problems medice10 3-Series (E36) 4 10-09-2005 03:10 PM
Climate Control Rookie 3-Series (E36) 9 03-14-2005 11:51 AM
