Broken Blinds! - BMW Forum - BimmerWerkz.com
Old 11-18-2008, 11:17 AM   #1 (permalink)
Car: 1998 528i, AT, Gray w/NAV
BMWCAPT is on a distinguished road
Broken Blinds!
Greetings, I'm a new subscriber and need advice on removal of rear quarter-window roller blinds. I just purchased a 1998 528i and have been having trouble figuring this out... any ideas? Ideas about where to find interior repair parts would be a big help also.
Thanks very much, Tim
BMWCAPT is offline   Reply With Quote
Old 11-26-2008, 10:42 AM   #2 (permalink)
Car: 2003 525i
mhopper_2000 is on a distinguished road
Send a message via ICQ to mhopper_2000 Send a message via Yahoo to mhopper_2000
Did you receive help with this issue? Mine broke recently and I was told to go to the dealer for repairs. That could get costly.
mhopper_2000 is offline   Reply With Quote
Old 11-26-2008, 01:13 PM   #3 (permalink)
Broken Quarter Window Roller Blinds - 528i
Found that removal and replacement is straightforward. There's a screwdriver slot on the top rear edge of the roller blind. Insert a thin bladed screwdriver or other tool into the slot at an upward angle. Lift the spring clip and pivot the roller blind out at the top to remove. Two spring steel clips hold the assembly into the door frame and it may take a little patience until you get the hang of it. I was told that repair is probably not an option before I removed mine, and found that to be true. I also heard that you can find them for approx $125 ea. but my dealer wants more than that for the replacement blinds. Pls let me know if you find them cheaper anywhere else.
Hope this helps and good luck!
735 1998, rear window roller blinds phil 1,6,7,8 - Series and Mini Cooper 3 02-08-2011 05:02 AM
Got a broken Bimmer? needbrokenbimmer 3-Series (E36) 1 08-06-2008 03:08 PM
Broken Subframe? 325i_family 3-Series (E36) 3 12-10-2005 01:12 PM
I believe I may have broken something.... KingScare 3-Series (E36) 3 08-28-2004 01:17 PM
