Brake PROblems NEEd advice - BMW Forum - BimmerWerkz.com
Old 02-12-2006, 09:21 PM   #1 (permalink)
deeablos is on a distinguished road
Hello
I have a 5.25 e60
I get a lot of noise (squealing) when i apply brakes
carried the car to the dealership to have things checked out
and was told nothing was wrong
Got back the car and it makes a lot of noise still
I will appreciate any info how to solve the noise problem
deeablos is offline   Reply With Quote
Old 02-13-2006, 10:40 AM   #2 (permalink)
bimmerboy328i's Avatar
bimmerboy328i is an unknown quantity at this point
Send a message via AIM to bimmerboy328i
Did you install aftermarket brakes?
- 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD -
bimmerboy328i is offline   Reply With Quote
Old 02-14-2006, 10:21 AM   #3 (permalink)
BeelZibub is an unknown quantity at this point
I bet like me you drive hard and therefore brake hard! If so, it's not unusual to get squeels at low speeds as you will have polished the surfaces of your pads and disks like mirrors.
Also, some pads just squeel - I have had several sets on my e39 already, some have squeeled all the time (after a couple of months bedding in) and others just at the end of their life.
yOU USED TO GET "ANTI SQUEEL SHIMS" with every set of pads you bought (at least over here you did), which were a thin peice of tin which sat between your pads and the caliper - they really did work. Seems you just don't get these any more.
If you don't mind getting your hands dirty, remove the pads and liberally coat the back of them with "COPPER GREASE", this usually works as well as anti squeel shims.
If you don't like to get you hands dirty and BMW can't find a problem there's not much you can do other than put up with it or pay for some replacement pads and hope they are better.
Just on the side, I know how bad it feels to pull up in a heavily pedestrianised area in what's supposed to be a luxury saloon only to have heads turn not to admire you ride but in distaint at the horrible high pitched squeel it emits as you stop.
Good luck
Beelz
BeelZibub is offline   Reply With Quote
Old 02-15-2006, 08:30 PM   #4 (permalink)
Que
Que is on a distinguished road
Send a message via AIM to Que
RE: Brakes Problem
There Is Something Called A Antisqueal Paste It's Not Expensive It's Like 2.00 For The Most U Apply That On The Back Of The Pads And That Should Take Care Of You're Problems, If That Doesn't Work You Should Try Using Dustfree Pads, It's More Cheaper Than The Original Pads And It's Not Metalic Like The Orginal, Dustfree Pads Comes In Two Brands Pbr And Mintex, But The Pbr's Are The Best Don't Forget The Paste It Really Works
ETK don't have nuttin on me
Que is offline   Reply With Quote
Old 02-17-2006, 08:26 AM   #5 (permalink)
dirtybeemer's Avatar
dirtybeemer is on a distinguished road
I have the same problem with my 523i, yesterday i took the rear pads out and coverd them in copper grease but i couldnt shift the hex bolts on front with the allen key i was using, as i couldnt find the allen key i have specially for doing brakes bolts so at the minute the rear is cured but the front is still squealing so until i find my proper tool and get round to doing them ill just have to put up with the squeal which isnt as bad as what it was and when im driving with the radio on its non exsistant inside the car.
dirtybeemer is offline   Reply With Quote
Old 02-17-2006, 05:27 PM   #6 (permalink)
See, the good old fashioned Copper grease really does work - I've used it for the last 15 yrs and it's not let me down yet (Though at the moment I can't be arsed and put up with the squeel)
PS where you from dirtybeemer - I guess Europe and most likely UK as you have a 523i
Old 02-24-2006, 07:50 PM   #7 (permalink)
Thumbs up
Hi Beelzibub sorry for the late reply been having a few pc problems but sorted know yeah im in england in a little town called Grimsby, where about are you from
1990 518i - engine problems and advice for a novice!! RichardMichael 5-Series (E12,E28, E34, E39, E60) 6 02-08-2006 02:18 PM
325e Brake Calipers ... Problems Help! beefey 3-Series (E21, E30) 0 06-12-2005 12:03 AM
Rear Brake Problems nstg8 1 3-Series (E21, E30) 1 04-21-2005 06:14 AM
Brake problems.... antose9 5-Series (E12,E28, E34, E39, E60) 3 06-02-2004 06:04 PM
