Brake pedal "slips" ? - BMW Forum - BimmerWerkz.com
Old 01-23-2004, 05:36 PM   #1 (permalink)
Ok, ive had this problem for a while now, but its never acted up often until now.
usually after my car had been parked for a while, when i first start it up, i would apply the brakes, it would be firm then id feel a "slip" and it would go down easily then it would be firm again.
Just the other night i noticed it happen while driving, and then this morning after starting it up.
Since ive noticed this problem, the brakes feel a good deal "mooshier" than they once did.
Fluid isnt up to the max mark, but it doesnt look empty either. does anybody have any ideas???
thanks guys.
Old 01-23-2004, 05:41 PM   #2 (permalink)
BMWL2's Avatar
BMWL2 is an unknown quantity at this point
Send a message via AIM to BMWL2
it might be low on fluid or you may have some air in your lines Probably wouldnt hurt to flush your system anyways
Motovated Motorsport Forums
http://www.motovatedcc.com
BMWL2 is offline   Reply With Quote
Old 01-24-2004, 04:04 PM   #3 (permalink)
TECH's Avatar
The master cylinder seals are probably leaking fluid internally, not holding the pressure. I'd get it fixed asap. Unless you have a leak and the fluid in the reservoir was emptied, you shouldn't have air in the system. You can try bleeding them first though.
Old 01-24-2004, 10:43 PM   #4 (permalink)
So your saying the master cylinder needs replacement?
is it a hard job to do??
thanks again!
Old 01-25-2004, 11:14 AM   #5 (permalink)
TECH's Avatar
thanks again!
It's likely that it needs replacing.
Hard to do? Not for me. :P It's not hard. You'll have to break the lines loose and unbolt it from the booster, and then bleed the whole system.
BMW brake pedals do seem to be a bit soft compared to others though. If your's feels abnormal, then it is probably the master.
Old 01-25-2004, 11:47 AM   #6 (permalink)
fuzyfuzer is an unknown quantity at this point
my 528 has a soft pedal and had the dealership look at it and they said it was normal had them bleed it when they replaced the rotars and pads but it did not change then i drive my neighbors 540 and it is even softer but when i drive my dads z4 it is hard as a rock i just don't get it
fuzyfuzer is offline   Reply With Quote
Old 01-25-2004, 03:47 PM   #7 (permalink)
ok, im going to try to put some new fluid in, the current stuff is pretty old. My question is... will it hurt to mix different brand fluids? im not sure whats in there now...
also will it hurt to put in the ATE super blue fluid with the current stuff in there?
thanks guys!!
Old 01-25-2004, 09:09 PM   #8 (permalink)
TECH's Avatar
If you flush the system, you'll have all one kind in there anyway. If you simply want to add a little, just as long as it's the same DOT as the other fluid, its ok.
Use dot 4.
Old 01-26-2004, 08:44 PM   #9 (permalink)
EXtech's Avatar
I wouldn't mix the blue with the original. They have completely different characteristics and boiling points. Flush the system to rid of the old and then put in the blue. Have you had any abs/brake lights come on when this "slip" happens? Flushing the system completely and replacing the fluid should help with the soft pedal.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 01-26-2004, 10:10 PM   #10 (permalink)
I've never had any warning lights except for the occasional brake LT circuit warning that comes on once a month and goes away if i shut the car off and restart it
Old 01-27-2004, 08:43 AM   #11 (permalink)
EXtech's Avatar
just trying to determine if you were having an ABS module problem
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
E46 Brake Pedal Cover TUDM Classifieds Sell & Buy 1 07-28-2004 11:03 AM
Brake Pedal Travel CiscoKid 3-Series (E36) 6 07-12-2004 01:41 PM
Noisy brake Pedal... RudyandMarlene 5-Series (E12,E28, E34, E39, E60) 0 04-25-2004 06:10 PM
