--------Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost"."
Hints & Tips
thanks for the advice mate.
i was resetting the brake pad indicator but rather then setting it forward now it tells me that i'm 25000km overdue.
any idea how to change that?¿?
I have tryed all the steps and it still do not change .it say -15000 miles is there any other solution to this problem
Experienced the same problem, believe I understand now:
Its a problem with the brake wear sensor: I assumed my sensor didn't need replacing as I still had quite a lot of pad left (rear pads), and therefore didn't replace it. When I reset the service indicator it defaulted to -25 000 km's, and wouldn't budge. It looks like the sensor concept is slightly different on these later BMW's, which use a CBS (Condition-Based Servicing) concept: The CBS system assumes a basic lifetime, in the case of the rear brakes 25 000 km's, and start counting down. The wear sensor wears through when the pads still have quite a bit more life in them (not when the pads are pretty much done), and this allows the CBS to adjust its countdown more accurately for the last few thousand km's. So if you then just replace pads and try and reset the service indicator, the CBS system gets grumpy and gives you the service overdue treatment.
I replaced the wear sensor with a new genuine BMW part, and the system reset on the second try. It seems that you may need to perform the reset procedure a few times to get the reset.
Out of curiosity, I then re-plugged my old sensor, and when I turned on the ignition, I got a "Brake Sensor Fault" error message.
I compared resistance measurements across the new and ols sensors. The new sensor is a closed circuit, the old sensor is not open circuit, but gives 1.4Mega Ohms across the terminals.
In the attached photo you can see the new sensor (top) with a large wear section, and the old sensor (bottom) with this section worn away.
I have heard that non-original sensors may cause problems as well, so if you have replaced your pads and sensor and still can't reset, I suggest you try replacing with a genuine BMW sensor.
If anyone has still had the problem even with a BMW sensor, please post the details.
thank you for your great response. I have replaced the brake pads and i am very good with checking the prake pads regularly. Do i still have to change the brake sensors? my iDrive brake light is on and it does not turn off. I tried to reset it, but it does not work. I really appreciate any response.
