Brake Light Constently On! - BMW Forum - BimmerWerkz.com
Old 11-16-2004, 03:21 PM   #1 (permalink)
pherbolario is an unknown quantity at this point
Help!?!?!? I own a 1998 528i 5-speed. My e-brake light came on and it is constently ON even with the e-brake down. I have the peake research thing and it shows no error. Does anyone know what this means? How do I know when my brake fluid is low?
pherbolario is offline   Reply With Quote
Old 11-16-2004, 03:26 PM   #2 (permalink)
[snapback]232088[/snapback]
Maybe your brake pads are hung in the on position, did you check your brake lights to see if they are off, also slide under dash and hold the arm on the stop light switch in and see if that changes anything, I had an issue with my brake lights staying on and I had to adjust the brake pedal arm to fully seat the stop light switch arm.
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
HELP, e36 brake light curcuit fault code theogill 3-Series (E36) 4 08-27-2004 07:48 AM
After tail-light upgrade, left brake light is gone mostwired 3-Series (E36) 3 11-26-2003 05:13 PM
