Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 02-03-2004, 12:03 PM   #1 (permalink)
Photos: 0
pherbolario is an unknown quantity at this point
need a little help here...i changed my front brakes with the sensor and i still have the brake lamp light still on...does anyone know how to reset the light or something? i did not change the rear brake pads cause they are still good...
my mechanic told me to unplug the battery and then plug it back in to reset the brake lamp but he also said that you will need the radio code to use the radio again...is there a default code for the radio?
pherbolario is offline   Reply With Quote
Old 02-03-2004, 12:11 PM   #2 (permalink)
Mach 5's Avatar
Photos: 0
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
Turn the key to the run position and wait for about 11 sec. the light should go out.
Ben
You did replace the sensor also correct?
"It's not because I'm an aggressive driver, it's because I'm an idiot" actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 02-03-2004, 01:30 PM   #3 (permalink)
Photos: 0
well my mechanic did it so i sure hope so...i'll try it tonight when i get home from work...thanks
Old 02-03-2004, 04:43 PM   #4 (permalink)
Photos: 0
RichReg is an unknown quantity at this point
Hmmm....I think your mechanic is mistaken. I had the same problem & when I disconnected the battery on my 323Ci, the sensor light went out but I had no problem using the radio afterwards.
R.R.
RichReg is offline   Reply With Quote
Old 02-03-2004, 04:57 PM   #5 (permalink)
Photos: 0
on the newer cars, i dont think the radios are code protected.
the code is supplied with the car when its bought and if you dont have it, id get ahold of BMW and have your proof of ownership, vin and every other peice of important information ready so you can get the code beforehand.
Old 02-03-2004, 07:43 PM   #6 (permalink)
EXtech's Avatar
Photos: 0
the mechanic IS mistaken. Put the key in, turn to position II and leave it on for 10-15 seconds. The light should go out and you'll be on your way. You are looking at the brake lining light and not the park brake light aren't you?
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 02-04-2004, 10:33 AM   #7 (permalink)
Photos: 0
thanks extech!!! it worked!!! yea, i meant the brake lining light...
vB code is On
Parking brake not releasing GnarlyCow 3-Series (E46, E90) 13 07-29-2004 04:39 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
