| Team, I'm the proudly owner of one excellent E28, 5353is. My problem is, the front passenger side caliper is getting applied and braking alone. I replaced both front calipers and pads. Bleed it correctly starting from the rear right,following rear left, then front right and ending with the front left. The car has ABS. When I start driving, around 5 or 8 minutes later, the car start to run slowly. When I check the passenger side front caliper is completely applied, if I open the bleeder screw, it throw the fluid without bubbles, air neither, and comes back to normal until 10 or 15 minutes again. Is it possible the ABS is damaged?
Thanks for the support. |
