brake booster check valve - BMW Forum - BimmerWerkz.com
Old 01-09-2004, 02:58 AM   #1 (permalink)
val&525i is an unknown quantity at this point
Hi guys!!
I have idle problems with my 525i M20 engine.
While checking for vacuum leakage I noticed that the engine sucks air thru a small onep ended hose mounted on the brake booster's check valve (vacuum line).
I am wondering if this is normal since the air is not measured by the AFM.
Thanks!
val&525i is offline   Reply With Quote
Old 01-09-2004, 11:22 AM   #2 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
that line fell off of something ive never seen a booster suck air from a hose of anysort unless it was directly hooked up to a solenoid or valve.. get a drop light and have a look around the area of that hose it most likley fell off its fitting and the air the lack of opening and closing that particular part has cuased your idle to go to crap....
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 01-12-2004, 01:07 AM   #3 (permalink)
Thanks! I found that the thin vacuum hose that goes inside was disconnected. I reconnected it but this morning I still had a hunting idle when cold for 2 min.
Old 01-12-2004, 12:08 PM   #4 (permalink)
CBA
CBA's Avatar
check the area around the hose for leaks. being exposed to the elements may have caused it to stiffin up at the neck and continue leaking.
-Founder
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
Warning! Cashier's Check Fraud L337E46 Classifieds Sell & Buy 2 03-06-2004 03:04 PM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
