Brake Bleeding - BMW Forum - BimmerWerkz.com
Old 10-10-2004, 12:57 PM   #1 (permalink)
Goose is an unknown quantity at this point
Send a message via MSN to Goose Send a message via Yahoo to Goose
Evening All Forum Users,
Just a quick enqiry, I have changed the front pads on my BMW 520I 1990.
I am under gonig bleeding them as they are quite spongy.
Is there any sequence in which i should bleed the brakes of the car?
Doesn't seem to be al that great at the moment and could really do with some help.
Thanks very much
Scotty
<span style='font-size:15pt;line-height:100%'><span style='color:blue'>!!!!***SCOTTY***!!!!</span></span>
<a href='http://www.Motorbiking.vze.com/' target='_blank'>http://www.Motorbiking.vze.com/</a>
Goose is offline   Reply With Quote
Old 10-10-2004, 10:09 PM   #2 (permalink)
billB's Avatar
Goose
1. you changed the front pads; did you check the back ones?
2. Bleeding IF NEEDED (i.e. changing caliber/hoses) usually when changing break pads ONLY there is no need for bleeding; bleeding constitute getting the AIR out of the lines/system; air will not get into the lines by simply pushing back the caliber piston; unless you loosen one of the hoses (that is open a closed system); did you?
regards
billb
Old 10-10-2004, 10:12 PM   #3 (permalink)
/Banned
xsperf's Avatar
xsperf is an unknown quantity at this point
the correct order is:
back right
back left
front right
front left
that is the proper way to bleed them
xsperf is offline   Reply With Quote
Old 10-11-2004, 01:10 PM   #4 (permalink)
Thanks very much for that.
I actually replaced the entire caliper and pads on the front wheels.
So i needed to bleed them.
Front Right Brake Stopped Workin While Bleeding javieruz 3-Series (E21, E30) 9 12-23-2004 07:13 PM
Parking brake not releasing GnarlyCow 3-Series (E46, E90) 13 07-29-2004 03:39 AM
BRAKE BLEEDING pbatarse M-Series (M1, M3, M5, M6) 6 04-09-2004 07:20 PM
