Brack Pads Sensor - BMW Forum - BimmerWerkz.com
Old 04-11-2005, 09:21 PM   #1 (permalink)
Rkhoubian is an unknown quantity at this point
Hi guys
I 've changed brake pads on my E39 whithout braking sensors but lamp on my dush panel still lighting. Do you know if I need to reset system or must be some thing wrong with a sensor.
Best Regards
Rkhoubian is offline   Reply With Quote
Old 04-11-2005, 11:44 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
once the lining lamp is on it is because a sensor has been damaged. They are designed that when the brake pads get below a certain threshold they actually wear through the sensor itself. So, because of this whenever replacing brake pads that have caused the lamp to come on ou must always replace the affected sensor as well. Once you have replaced the sensor or sensors that were damaged if the light still will not go out then try leaving the key in the on position with the engine not running for roughly 2 minutes. This should reset the warning lamp.
DT
DT
Old 04-12-2005, 05:33 AM   #3 (permalink)
DT
[snapback]330582[/snapback]
Thanks a lot man
rear Brake pads and sensor El Presidente Classifieds Sell & Buy 0 08-31-2004 12:35 AM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
New Car - Few Problems, Any Help Appreciated. Sagan 3-Series (E36) 8 05-16-2004 09:28 PM
ABS sensor light fault.. Ski Bimmer Talk/Motorsports Talk 6 04-18-2003 08:38 PM
