The Bottom To Opne My Trunk Is Sticking? - BMW Forum - BimmerWerkz.com
Old 01-12-2005, 09:32 PM   #1 (permalink)
Scotty Dangles is an unknown quantity at this point
Hey Guys,
I need some advice on how to fix the opening mechanism for me trunk. Firts off when I push it down it sticks, and I need to use my key to pull it out. This makes me a little nervous, is there anything I can do fix this!!
Second there is a slight showing of rust that I want to address around the bottom half of the button, is this something I can fix or something I need to bring to a body shop??
Any help would be greatly appreciated.
See attached for picture!
Thanks
Scott
EDIT: Apparently I can't spell...I meant the button to open my trunk is sticking...?? ghead
Scotty Dangles is offline   Reply With Quote
Old 01-12-2005, 09:49 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
Have you tried lubing the mechanism yet? Sometimes a lil lubricant can go a long way. If that doesnt work then this isnt too difficult to get the panel off and access the lock unit. Just a few 1/4 turn fasteners and the panel will pull down and all that is needed to remove the lock assembly is regular hand tools. If you can get it out then you can see better what may be causing it to jam up.
Good Luck
DT
DT
Old 01-12-2005, 11:06 PM   #3 (permalink)
Good Luck
DT
[snapback]270433[/snapback]
Awesome!
Thanks for the tip!
Cheers
Scott
Trunk Will Not Open!!!! blacknite 5-Series (E12,E28, E34, E39, E60) 3 12-28-2011 03:10 PM
Trunk Problem rakeshp 5-Series (E12,E28, E34, E39, E60) 4 07-07-2005 12:33 PM
Trunk Light Stays On rakeshp 5-Series (E12,E28, E34, E39, E60) 3 05-09-2005 02:46 PM
Ultimate E39 Trunk Mod... 3 Bodies Illustration Dwayne 5-Series (E12,E28, E34, E39, E60) 3 11-03-2004 09:25 AM
Trunk spinning continuously deadseasquirrels 1,6,7,8 - Series and Mini Cooper 2 08-07-2003 10:30 PM
