Boot lid does not lock - BMW Forum - BimmerWerkz.com
Old 05-25-2006, 09:50 AM   #1 (permalink)
arh
arh is an unknown quantity at this point
Hi
I have just found that my bootlid is not locking on my 1999 E39. Dash keeps showing bootlid open and it does not lock with the key. It has just happened today. Could it be the locking solenoid or something else? Is there anything I can check? Could it be a mechanical fault rather than electrical?
Thanks
arh is offline   Reply With Quote
Old 05-25-2006, 10:07 AM   #2 (permalink)
cnn
cnn is on a distinguished road
Sounds like trunk lock actuator
Originally Posted by arh
Hi
Thanks
Go to realoem.com to see the part number.
Very easy DIY item.
cn
cnn is offline   Reply With Quote
Old 05-25-2006, 01:45 PM   #3 (permalink)
arh
More info
I can not lock it with the key and only sometimes I can hear the solenoid sound when pressing the boot button. Could it be the switch or the solenoid? Should it not lock with the key? Could it be the mechanism itself?
Old 05-25-2006, 03:46 PM   #4 (permalink)
cnn
This may help you
http://www.bmwtips.com/tipsntricks/t...20actuator.htm
Let me know if you need more help.
Basically a DIY item.
cn
Old 05-25-2006, 10:44 PM   #5 (permalink)
winters97E39's Avatar
Car: 1997 BMW 528i
winters97E39 is a jewel in the roughwinters97E39 is a jewel in the roughwinters97E39 is a jewel in the rough
Send a message via ICQ to winters97E39 Send a message via AIM to winters97E39
I concur. I had the same issue on mine. replaced the actuator.. BAM! good as new.
Jason / 1997 528i
winters97E39 is offline   Reply With Quote
Old 05-25-2006, 11:01 PM   #6 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
+1 on actuator...
Old 05-26-2006, 05:24 PM   #7 (permalink)
arh
It was the spring
The actuator turned out to be fine and the issue ended up being a broken spring on the boot latch.
Old 04-06-2007, 04:23 AM   #8 (permalink)
mi5tery is on a distinguished road
Hi,
I'm new to the site - found it because of this topic.
I'm having the same problem as was mentioned here initially - boot has stopped locking shut (can just push it back up and open!), but when I press the open boot button on my key, I can hear the electric opening mechanism thing, but nothing is moving.
I think I may also have a broken spring - how do I change this spring? Any ideas?
Thank you in advance for your help.
-mi5tery-
mi5tery is offline   Reply With Quote
Old 04-08-2007, 08:34 AM   #9 (permalink)
For anyone with the same problem I worked it out by using the link given by cnn (How to Replace the Trunk Lock Actuator on an e39) to remove the boot lock actuator.
Then I located the broken spring from within the actuator part. I didn't even buy a new one - I used one long nosed plier and a cutter (because it was at hand and probably the best tool I had for the job - be careful not to cut the spring) to bend the broken end into a loop. I then reseated the spring - this took some fiddling - but I worked out that the bit which is most accessible is the hardest to seat the spring on - so I put the reshaped bit I made on this easily accessible bit first then seated the "good loop" on the other end (very fiddly).
Put everything back together again and hey presto my boot locks again!
Thanks cnn.
-mi5tery-
Old 08-18-2007, 08:43 AM   #10 (permalink)
ronaldmacdonald is on a distinguished road
boot doesnt lock
I have the same probem, the spring in the old actuator looks good. I purchased a new actuator and the problem still exists. Fuse looks good. Cannot lock with a key either. If i push the boot lock shut with a penor something I can unlock it with the boot unlock button but nothing on this planet will get it to lock!
ronaldmacdonald is offline   Reply With Quote
Old 12-11-2007, 06:01 AM   #11 (permalink)
tinsohtee is on a distinguished road
boot doesnt lock
Thanks! - had exactly same problem and followed your instructions with re-forming loop in spring and all works fine now. Just remember to take the middle bit' of the retaining plastic clips out to release the trim covering access to the torx screws.
Thanks again!
tinsohtee is offline   Reply With Quote
Old 09-27-2008, 06:00 PM   #12 (permalink)
WNeill's Avatar
Car: 1999 BMW 520i SE
WNeill is on a distinguished road
Thanks a lot for the tip mi5tery, Ive used an rubber band right now as I couldnt re-form the spring (embarrassing!!), but I will get another spring as soon as I can be bothered, rubber band works good enough right now
WNeill is offline   Reply With Quote
Old 12-03-2008, 07:15 AM   #13 (permalink)
It's been a while since I've been on the forums, glad to have been of service tinsohtee and WNeill.
WNeill I do hope you've managed to get that replacement spring (or reshape the end) as with winter upon us the rubber band may not last very long. Novel solution by the way! =)
Old 02-01-2009, 07:22 AM   #14 (permalink)
Car: 1998 540i, 1993 Pug 1.9, 1975 MGB
540i Quad pipe is on a distinguished road
Thanks from me too mi5tery - using two pairs of long-nosed pliers, we were as good as new in a couple of minutes.
540i Quad pipe is offline   Reply With Quote
Old 02-01-2009, 12:20 PM   #15 (permalink)
You're most welcome 540i Quad pipe, glad to be of service. =)
Btw, I think using two long-nosed pliers as you did, is a much better idea then mine with using a cutter (but I was lazy and couldn't be bothered to look for another one - lol). =)
NEW! Matching Shifter and E-brake Boot SET E30 E36 get rid of old rubber e-brake boot customshiftboot Aftermarket Parts 1 05-18-2006 11:52 AM
NEW! Matching Shifter and E-brake Boot SET E30 E36 get rid of old rubber e-brake boot customshiftboot Aftermarket Parts 0 03-19-2006 05:20 PM
NEW MATCHING SHIFT & E-BRAKE BOOT SET BMW E30 318 325, E36 shift boot customshiftboot Aftermarket Parts 0 03-01-2006 12:38 PM
Boot Lock storme 3-Series (E46, E90) 2 08-25-2005 12:13 PM
Lock On My Boot djmacca 3-Series (E21, E30) 3 01-24-2005 04:27 AM
