BMW E34 Crankshaft position sensor - BMW Forum - BimmerWerkz.com
Old 06-02-2008, 01:52 PM   #1 (permalink)
Car: 1992 BMW E34 520i
Rolandos147 is on a distinguished road
Hi I've got bmw e34 520i vanos 1992 year.. i just did alot of work on it by putting new engine my previous engine was 520i as well but it was non vanos, now i've got vanos which is slightly better but any way something went wrong with it doing my first test drive with new engine was ok it seemed to be much better than the old one i got 120 miles/h pretty easy after high revs and power tests i drive back home parked up and came back to my car after 20 min. went for another drive and weird things start happening i felt that i can nearly move got back on road floor it and in 2nd gear it could only do 5500 rpm and i could feel loads of misfiring, first thing i looked on temp but it was fine and there wasnt any mechanical faults on it engine sounded ok especially when running idle very smooth no misfiring any i ignore all that kept diving around later on that evening i parked up and my engine was running idle for 15 min and it sounded perfect! so i turned my ignition off than after another 15 minutes i try to start it and that was it, it never started up, actual engine was cranking but there was no sound of live in it like some one cut off petrol and spark! after many things i went thru i got it started some how but it was very badly misfiring i checked the timing it was perfect injection system and spark plugs were ok so i start checking all the sensors and i end up wit weird thing when i disconnect my crankshaft position sensor engine still runs with no change i replace the sensor but still no chang so its down to ECU now or maybe any one of you people have any other suggestions or maybe some one had the same problem??? And is it actually possible to reset my ecu???
Rolandos147 is offline   Reply With Quote
Old 06-02-2008, 02:02 PM   #2 (permalink)
here is some pic of engine i rebuild!!
BMW E34 Crankshaft position sensor-img_5639.jpg   BMW E34 Crankshaft position sensor-img_5640.jpg   BMW E34 Crankshaft position sensor-img_5652.jpg   BMW E34 Crankshaft position sensor-img_5737.jpg   BMW E34 Crankshaft position sensor-img_5742.jpg
Old 06-02-2008, 02:06 PM   #3 (permalink)
And some more i had wiring loom so i could start my engine in garage and still see temp of it and rpm!!! pretty handsome!!!
BMW E34 Crankshaft position sensor-img_5745.jpg   BMW E34 Crankshaft position sensor-img_5750.jpg   BMW E34 Crankshaft position sensor-img_5754.jpg   BMW E34 Crankshaft position sensor-img_5755.jpg   BMW E34 Crankshaft position sensor-img_5770.jpg
Old 06-02-2008, 02:09 PM   #4 (permalink)
BMW E34 Crankshaft position sensor-img_5771.jpg   BMW E34 Crankshaft position sensor-img_5779.jpg
Old 06-03-2008, 11:20 PM   #5 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Cool
disconnect battery and leave it overnight. that will reset your ECU to it's original state.
as of this writing, i am nt sure if the ECU sans vanos is compatible with vanos... in all likelihood, what u are seeing is an ECU mismatch because the vanos mapping is distinctly different from non-vanos ;-)
Old 06-04-2008, 02:10 PM   #6 (permalink)
well i tried to leave it overnight with no battery, that didnt made any changes!! this ecu is original i took it off with all the engine and wiring loom cos i bought the whole car with this vanos engine just for spares!!! well i booked my self in BMW garage but i still have to wait until Tuesday thats like another 6 days but when i will get answer i will type it in here!!!
Old 03-12-2012, 07:50 PM   #7 (permalink)
shaun535i is on a distinguished road
hello,
looks like i have the same issue.
just wont start.
changed crank
air flow
fuel pump
sparks...
what happened to your car-how did u solve it?
shaun535i is offline   Reply With Quote
Old 03-13-2012, 10:59 AM   #8 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
OP, that's a really nice engine! I love the custom paint. Is that powder coated or just hi temp paint?
Click HERE to see my E36 Blog
Camshaft Position Sensor nwiles 5-Series (E12,E28, E34, E39, E60) 1 08-07-2007 12:01 AM
FS: Camshaft Position Sensor - Intake GRIDLOCK OEM Parts 0 05-25-2007 06:29 PM
E34 pistons, connecting rods and Crankshaft Saggis 5-Series (E12,E28, E34, E39, E60) 0 03-23-2006 03:03 AM
Camshaft Position Sensor gigsy 5-Series (E12,E28, E34, E39, E60) 1 10-24-2005 12:08 AM
Picture of Throttle Position Sensor? tourist 3-Series (E36) 4 12-22-2003 02:06 AM
