Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 06-05-2005, 10:50 PM   #1 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3 | 1983 Yamaha something
Photos: 0
Look at these two pictures. I think im missing a belt some some sort. My power steering seems to have died, my cluster shows the battery symbol, anti-lock brakes, and parking break.
Any help appreciated.
bmw-e34-alternator-belt-dsc02004__medium_.jpg  bmw-e34-alternator-belt-dsc02005__medium_.jpg
Old 06-05-2005, 11:22 PM   #2 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
sometimes when one belt goes, it will take another belt with it. you are missing 2 belts at least. both run off of a different pulley from the way it shows they are lined up in the picture.
our cars have 3 belts, so you might make sure the third one is still there. go ahead and replace that one two, when you get your other 2. they are usually changed out at the same time and im sure the 3rd one is worn as well.
they are easy to change, you just have to do the rear one first and work your way to the front one.
-There's no place like 127.0.0.1
-"Wheel Sucks"
Old 06-05-2005, 11:23 PM   #3 (permalink)
Keep it Copacetic
///M Power's Avatar
Photos: 0
Thanks a lot. By the way mien is a m20. Im mad. I drove to work adn back withotu power steering.
What are the names of the three belts?
I knew there were at least two belts cuz i didnt think a serpentine belt would do the trick here.
Old 06-05-2005, 11:33 PM   #4 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
loosen "A", then loosen "B". "B" will adjust the amount of tension after the belt is reinstalled. Just go to your local dealer, or a parts place you can trust and tell them you need all the "V" belts for you car.
There are small gears (that can be stripped out easily) where "A" is bolted to, you will see them.
You will need to make sure the belts are in line correctly with the crankshaft (the one that has three grooves for belts to reside on) pulley.
Hope that helps....
-"Wheel Sucks"
Old 06-06-2005, 12:19 AM   #5 (permalink)
Keep it Copacetic
///M Power's Avatar
Photos: 0
Alright. And I guess this is the OBVious reaosn my battery sign is up. No alternator power :-. Why my car is overheating. Poor waterpump and why MY POWER STEERING DIED....typical e34m20.
So the fluid that was leakign I assume splashed onto parts that contorl power steering. Immobilizign it. I guess these are the components in my car when they get wet in rain or after washign the carkill my power steering. Eh?
Do you know which parts specifically are related to my PS?
Old 06-06-2005, 07:01 PM   #6 (permalink)
Keep it Copacetic
///M Power's Avatar
Photos: 0
Ok well i took it to the shop and got all 3 belts done.
Now im stil overheating. I opened up the thermostat. Somethign is wrong. Either the water pump isnt pushing any fluid or the thermostat isnt allowing any by. The thermostat was in great condition. So i dont plan on checkign the wtaer pump cuz of location> Dropped it off at teh shop for a diagnosis.
Heres a theory. Maybe the water pump was bad int he first place. Maybe misaligned or something. Maybe then it caused the belt to be awkard adn snap, takign out te the belts too. So maybe the water pump was my original problem, and eveyrthign after being a symptom?
Maybe?
How about the fan clutch? Here could be the heating problem!>?
Old 06-06-2005, 08:52 PM   #7 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
Yeah thats possible. If the water pump would have ceased to turn (locked up), it may have thrown the belt.
-"Wheel Sucks"
Old 06-07-2005, 05:54 PM   #8 (permalink)
Keep it Copacetic
///M Power's Avatar
Photos: 0
I guess. When the belts were off I manually spun the water pump i believe and it worked fine. Any other ideas?
Old 06-07-2005, 11:07 PM   #9 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
sometimes the plastic impeller inside the water pump breaks. from the outside it would look like it would spin and be ok, but no water is moving on the inside.
-"Wheel Sucks"
Old 06-08-2005, 02:58 AM   #10 (permalink)
Keep it Copacetic
///M Power's Avatar
Photos: 0
Good. that's why this tiem i made sure i got a metal one. Problem fixed, thanks a lot for the help Da_bull.
By the way, what part of missouri do you live in? live in midtown st louis during the school year.
Old 06-08-2005, 05:59 AM   #11 (permalink)
da_administrator
da_bull's Avatar
Photos: 0
glad you got it going. I live down in Springfield...home of the Bass Pro m :P . I visit St Louis 2-3 times a year. Maybe I'll catch ya driving around. I'll be up there in mid-September for a meet (non-car related) with some friends of mine
-"Wheel Sucks"
Old 06-08-2005, 06:37 PM   #12 (permalink)
Keep it Copacetic
///M Power's Avatar
Photos: 0
No car in st louis, just stays here in california.
vB code is On
H&R Cup on an E36 Convertible RJHD3 3-Series (E36) 7 10-19-2005 02:34 AM
BMW and SIRIUS Satellite Radio Extend Exclusive Relationship 97alpineM3 News 0 09-19-2005 10:45 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
