Bmw 525 touring 2005 Fault Code P0193 - BMW Forum - BimmerWerkz.com
Old 11-23-2011, 09:53 AM   #1 (permalink)
canetas is on a distinguished road
Unhappy Bmw 525 touring 2005 Fault Code P0193
I am currently the owner of a BMW 525d wagon, 130kw, 2005. The same was working with a PowerBox.
Due to want to sell the van this year, when I removed the chip, and reconnect the original chips, I came across a notice-board computer to say, increased emissions, please head over to the BMW.
Reconnected the chip and the van will not turn on, i´ve pluged in the origana plugs and it turned on.
But the ECU fault continues...
When i connect the chip to the plugs, the van doens´t start, and produces 1028bares nominal rail pressure ad 1028bares real rail pressure I switch of the plug, it produces 400bares nominal rail pressure ad 400bares real rail pressure, this kind of pressure is made without the van being ON. It doens´t produce power.. it looks like she is on SafeMode.
ECU fault codes:
3F30 – Rail Pressure sensor
signal interruption or short circuit to positive
4232 - third cylinder glow plug
What we´ve done:
checking the operation of the sensor - OK
continuity of the sensor wires to the ECU - OK
He was also made direct connection from the battery negative position, to the engine block.
What can it be?
canetas is offline   Reply With Quote
fault code e30dream 3-Series (E21, E30) 1 06-07-2008 11:20 PM
FXC-II Fault Code Henri 3-Series (E36) 3 03-30-2006 06:28 PM
Need help with fault code ! sycow 3-Series (E46, E90) 3 12-02-2005 04:48 PM
Fault Code BImmerN2B 3-Series (E36) 3 08-29-2005 05:38 AM
fault code boblynn1 1,6,7,8 - Series and Mini Cooper 1 09-28-2004 10:43 AM
