BMW 5 Series idling problem - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 07-23-2008, 07:28 AM Thread Starter
cosmosbimmer is on a distinguished road
Hello folks,
My BMW 523i has suddenly developed a strange problem recently.
The symptoms:
1. Car takes longer to start and struggles slightly to get up to the constant idling revs.
1. The power has decreased and I can notice the car's acceleration is irregular.
2. When the engine is running (for example, at a traffic signal) the engine suddenly stops.
3. When starting from standstill, I have to give more cluch action than normal, otherwise the car would stop.
I have replaced all the spark plugs and the oil and fuel filters (full service) and that doesn't help.
What has gone wrong with my baby?
Please help !!
cosmosbimmer is offline
post #2 of 6 (permalink) Old 07-23-2008, 10:57 AM
darkhorse737's Avatar
Quoted: 2 Post(s)
Arrow
Q1: did you replace the plug BEFORE?... or AFTER your probs started?
Q2: with a COLD engine start-up how many RPM's does it idle at? and how many mins before it drops down to normal idle?
Q3: with a WARM engine, what is the RPM range at which your car runs?
Q4: did u check air filter, as well?
* anything else that u feel is relevant will help for us to diagnose by remote control "correctly" ;-)
darkhorse737 is offline
post #3 of 6 (permalink) Old 07-25-2008, 05:58 AM Thread Starter
thanks
Hi
Thanks for writing.
Q1) I have replaced the plugs after the problems have started.
Q2) At the cold engine start, the engine idles at around 700 rpm.
Q3) With warm engine, the car idles at around 500 to 600 rpm and I usually drive upto 5000 to 6000 rpm.
Q4) Yes, I have put a new air-filter (included in the full service)
Also, the car struggles to kick off when I press the accelerator. I hesitates a bit and then it slowly starts to pick up. But definitely the car has lost power.
Any ideas now please?
Thanks a million.
post #4 of 6 (permalink) Old 07-28-2008, 05:47 PM
stheaney2007 is on a distinguished road
mate this is happening to me too
Hi cosmosbimmer,
I have a 540i V8, just replaced the plugs and suddenly all power is gone, its missing badly and when i go into DRIVE it tries to stall until I hold the revs up
Keep me posted what your problem is
Thanks
stheaney2007 is offline
post #5 of 6 (permalink) Old 08-03-2008, 02:26 AM
CosmosBlack's Avatar
CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute
Any "white smoke" coming out of the exhaust?
Is there a "whistling" noise from the engine area on acceleration?
Does acceleration problem improve at higher speed?
If so, could be the Oil Separator....vacuum leak
2012 Porsche 911 GTS
2008 Ford F150 Foose Edition
2010 VW Touareg
Gone...2002 Porsche 911 C4S
Gone...2000 BMW 540i
Gone...1995 BMW 540i
CosmosBlack is offline
post #6 of 6 (permalink) Old 08-03-2008, 10:27 AM
Quoted: 2 Post(s)
Originally Posted by cosmosbimmer View Post
Hello folks,
The symptoms:
Please help !!
check fuel pressure and check for vacuum leaks. If you are sure those two are in order; the first part i will suspect is a Throttle switch...(aka Throttle Position Sensor)
Good Luck
E46 - Idling Problem Richard Lowe 3-Series (E46, E90) 5 11-12-2005 02:31 AM
1998 Bmw 528i Blowing Hot When In Idling 98bimmerhead 5-Series (E12,E28, E34, E39, E60) 4 08-17-2005 10:11 PM
Fast Idling JCooper60 5-Series (E12,E28, E34, E39, E60) 4 06-25-2004 04:53 PM
Strange idling problem. Batunas 5-Series (E12,E28, E34, E39, E60) 4 12-17-2003 12:56 PM
Idling issue bostonsports 3-Series (E21, E30) 5 05-10-2003 12:05 AM
