Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 10-20-2004, 04:20 PM   #1 (permalink)
Photos: 0
CaptainEL is an unknown quantity at this point
ghead PLEASE HELP.
Thought i would save some money and do a sevice on my 525i E34 BMW myself.
Done the oil and filter aswell as the air filter and plugs.
Having never put any anti freeze in the car i thought i would do this so i drained the radiator by removing the bottom hose and then replaced it and refilled it and then run the car to bleed the air out.
Well to cut a long story short i couldn't do it and now it is in a garage and it has had a new radiator new water pump and the head gasket re done and it still wont bleed out and the man in the garage doesnt seem to have a clue and the bill is getting bigger.
Has anyone got any ideas at all?????
CaptainEL is offline   Reply With Quote
Old 10-20-2004, 05:35 PM   #2 (permalink)
Idle Member
Photos: 0
llzoom_zoomll is an unknown quantity at this point
Send a message via AIM to llzoom_zoomll
well, there is a certain procedure to bleed the air out of many e34's. The key here is a bleed screw...It should be located right next to the radiator cap.
Procedure: remove radiator cap and unscrew pressure bleed screw right next to it. (the screws under the car should be closed by now.
fill the tank with 50/50 (BMW coolant/Distilled Water) until you see bubbles come out of the pressure bleed screw. Continue this until there are no more bubbles. The whole process will get a little messy with the coolant coming out of the pressure bleed screw...but then again, the key is gettin all the air out while you refill the system. oh and the car should be off while you fill...
for more help, go to http://www.bmwe34.net/e34main/maintenance/...replacement.htm or e-mail me
llzoom_zoomll@hotmail.com (those are L's btw)
good luck
You think gas is expensive? CHECK THIS OUT:
Lipton Ice Tea 16 oz $1.19 ...........$9.52 per gallon
Ocean Spray 16 oz $1.25 .......... $10.00 per gallon
Gatorade 20 oz $1.59 ..... $10.17 per gallon
Diet Snapple 16 oz $1.29 .......... $10.32 per gallon
Evian water9 oz $1.49..........$21.19 per gallon?
Brake Fluid 12 oz $3.15 ........... $33.60 per gallon
Pepto Bismol 4 oz $3.85 ........ $123.20 per gallon
Vick's Nyquil 6 oz $8.35 .... $178.13 per gallon
llzoom_zoomll is offline   Reply With Quote
Old 10-20-2004, 11:59 PM   #3 (permalink)
Idle Member
Photos: 0
any luck?
Old 10-21-2004, 02:25 PM   #4 (permalink)
Photos: 0
Yea i have it back now cost me £668 though.
Will look on that site before i do it again.
Thanks for the help
2" class="inlineimg" />
vB code is On
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
M3 Compression Test And Cooling System MadBMW M-Series (M3, M5, M6) 0 03-10-2005 09:47 PM
The American Vs. The German billB 5-Series (E12,E28, E34, E39, E60) 83 10-14-2004 07:09 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
