Best sohc m20 head? - BMW Forum - BimmerWerkz.com
Old 03-08-2006, 08:06 PM   #1 (permalink)
wheelerdealer is on a distinguished road
Best sohc m20 head?
I just bought my first bimmer project. It is a 1989 525i in mint condition besides the broken timing belt. ( ouch lol ) Well when it broke it some tabs off for on the head for the rocker arms so its junk. I was wondering if people put a head from a 3-series or something on these to make them run alot better?
Do people put dohc cam heads on these blocks?
what is a good website to check bmw head casting numbers?
thanks
alex
wheelerdealer is offline   Reply With Quote
Old 03-08-2006, 08:14 PM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Head is the same on 525i, 325i/is ...
You can't put 'dohc cam' heads on the m20 block ... there was no DOHC m20, and m50 head will not work on a m20 block unless you are some kind of magician.
check out www.realoem.com/bmw/select.do that might help you with the casting numbers
ps. edit: it wont run any better with a head from a 325 .. its same
Old 03-08-2006, 08:25 PM   #3 (permalink)
Is there any better year of head?
like bigger valves or better water passages?
Old 03-08-2006, 11:42 PM   #4 (permalink)
e34s used the latest version of the m20. It's the highest performance from the factory for the m20.
The best thing for performance is the late model i head on an older m20 2.8 eta block. That makes for good torque.
Maybe consider getting a set of cams and stiffer valve springs if you want more performance...
good luck
Old 03-09-2006, 05:16 AM   #5 (permalink)
da_administrator
da_bull's Avatar
Ya hear that Torque, you getcha one of those and that'll make you good. I dunno how, but nonetheless.
Old 03-09-2006, 10:04 AM   #6 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
I thought I already had a late model one. lol
07/90 build date ... either way I don't see how it would help anything.
Old 03-09-2006, 01:11 PM   #7 (permalink)
Would a head off a 1987 525e be the same? There is one on ebay cheap.
Old 03-09-2006, 08:25 PM   #8 (permalink)
da_administrator
da_bull's Avatar
I meant you personally, theres no help for our cars, less an M5 drive-train / suspension swap
Old 03-09-2006, 09:13 PM   #9 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
ah, yes m20 head for myself. i need help installing it tho.
btw, theres a e34-only meet in chicago on a saturday in april (i believe -- website down at the moment so i cant check) ... u should go.
im honestly considering going up there.
Old 03-10-2006, 05:22 AM   #10 (permalink)
da_administrator
da_bull's Avatar
Chicagos like an 8 hour drive for me. Maybe a little further than I want to drive. My two trips this year are the Street Rod Nationals in Louisville (that trip is long enough), and the Good Guys show in Kansas City (only a couple hours), I want to try to finish my street rod this year. I dunno, maybe???
Sorry for the hijack...
Old 03-10-2006, 01:31 PM   #11 (permalink)
a head from an e will decrease your performance. It has to be an i head.
The only e parts that enhance performance is the block. The e heads are restrictive, but the blocks are larger - so when mated with an i head, you effectively have a 2.8 liter m20 which can match output levels of a stock m50 b25
5 series head unit to amp question. Non DSP greenwave 5-Series (E12,E28, E34, E39, E60) 6 06-28-2007 10:23 PM
Best sohc m20 head? wheelerdealer 3-Series (E36) 1 03-08-2006 08:32 PM
Blown head gasket? Nigel-DV 3-Series (E36) 10 11-22-2005 02:34 PM
