There should be a 3 digit number on top of the battery... This denotes both the ampage and terminal layout, just quote it when enquiring about a replacement...
__________________ Eso es todo! Please press the "REP" button if you are happy with your response/answer...
Please JOIN, or just have a look... Its Totally FREE... BMW Part Market
Hi,
There are a lot of stories about replacement batteries, but I can only give you One good advice: buy an original BMW battery with EXACTLY THE SAME specifications as the original mounted battery.
Your cars computer is programmed with the battery parameters for charging current etcetera. After a battery replacement, the BMW dealer will do the registration procedure in the computer, but that makes it unnecessary expensive. Replacement and programming may match the battery costs.
A friendly BMW dealer who knows I am a good DIY mechanic told me that when the original battery is replaced with exactly the same one, it does not need registration/programming. The only thing then is that the computer has the 'old date' in its memory but will handle the battery as the original one.
The BMW battery will cost you about 25% more than the equivalent of the local carshop but it is worth it and it saves you the trouble of a mischarged battery, which may fail after 2 years.
will no longer take a charge so need to replace mine too ('96 318is) but the bmw batteries from the local dealership are so much more than comparable ones from battery stores or auto parts. switch out is easy. wish i had a suggestion or advice but i/we just need to decide whether to spend that extra money for something i/we really might not need.
