Bad Wheel Bearing!!!! Need Info. - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 12-03-2004, 09:15 AM Thread Starter
kanestron is an unknown quantity at this point
Ok so I own a 1998 528i. I'm hearing a mild to medium rumbling sound when I'm driving straight and turning left, however when I turn right the sound goes away. A friend of mine who's a mechanic said it sounds like my right front wheel bearing is going out.
Ok so I went online and was going to purchase bearings for both sides, what the hell if your going to do one side you might as well do both right? Any how when I went online all the sites sell wheel bearings for the rear, but I don't see anything for the front. Are they the same part???
The only thing I could find with regards to the front is the front "Wheel Hub Assembly".
If anyone has experience with this your info. would be much appreciated.
Thanx
kanestron is offline
post #2 of 8 (permalink) Old 12-03-2004, 10:20 AM
Moderator
Dirty_Tool's Avatar
Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute
Hi,
The front and rear wheel bearings are different. You were correct in finding that the front wheel bearing is in fact the hub, it is all 1 assembly. I am attaching a link to a diagram from http://realoem.com the wheel bearing is #5 in the picture (part # 31221093427) and also be sure that you replace the 4 bolts which hold it on, the bolts are listed below the bearing (#6 in the picture)
Also since they are not exactly cheap you may want to make sure that this sis not a tire noise before you start replacing bearings. Did you lift the front of the car and spin the wheels without the etires on the ground to confirm mthe noise? If not I would spend a few minutes doing that 1st. Also a real good tests is to spin the wheel and while it is turning grab the spring and feel to see if you can feel any roughness. If the bearing is fine it should feel nice and smooth, if the bearing is bad you wil feel the roughness of the bearing through the spring.
Hope this info helps, Good luck
DT
link to diagram
DT
Dirty_Tool is offline
post #3 of 8 (permalink) Old 12-03-2004, 03:24 PM
WindowPro's Avatar
WindowPro is an unknown quantity at this point
Kanestron:
If it turns out to be wheel bearings...
I've read a lot of good reviews about Zechhausen Racing. From what I have researched on their site and forums, they seem to have the best pricing and reputation.
Not tried them yet but plan to soon.
BTW - Nice advice Dirty Tool, you taught me something. Thanks!
Jim
<img src='http://img51.exs.cx/img51/2517/BMWFORUMSSIGNATURE.jpg' border='0' alt='user posted image' />[QUOTE]GIRLS...GIRLS...GIRLS
WindowPro is offline
post #4 of 8 (permalink) Old 12-03-2004, 03:55 PM
mixalot's Avatar
mixalot is an unknown quantity at this point
I repllaced my left rear wheel bearing this summer, after it began squeaking. There was no need to replace both.
Past ownership: 1987 325is, 1988 325i, 1995 325is, 1996 325i Convertible, 1994 325is.
Current ownership (wife's): 2006 X3 3.0i
Future ownership: 3-series of some sort
mixalot is offline
post #5 of 8 (permalink) Old 12-03-2004, 04:39 PM
billB's Avatar
billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute billB has a reputation beyond repute
I did the change 4 of them, the two hubs in front held by 4 bolts from the back where I replaced by new bolts from BMW (they come coated with thread locking compound see DT's remarks above). Difficulty? I say medium because one the bolts is hidden behind the strut nuckle (turned otherwise 1/2 job to 1 hour)
The back ones are NOT hubs and tend to live over the rear small shaft. I used a bearing puller to get them out, they did get separated though from the inner ring (they came off in 2 pieces/inner stuck to the shaft) but it was easier than the front ones. Once replaced the car will role way much better.
good luck
billB is offline
post #6 of 8 (permalink) Old 12-04-2004, 12:46 PM
Moderator
Dirty_Tool's Avatar
Coincidentally enough i was browsing www.bmwtips.com and came across this link written by DaveZ. It has a really nice DIY with great pictures and step by step instructions also part #s which we already covered but the pics of the parts are much much clearer than the parts diagram which i posted for you. Im sure this will help out a lot if you're gonna do his job yourself.
DT
http://bmwtips.com/tipsntricks/DZ/bearing.htm
DT
post #7 of 8 (permalink) Old 12-06-2004, 03:27 PM Thread Starter
Thanks for all your help fellas. I have the hub ass. on order and will be recieving it soon. I think I'll tackle this one myself, it looks pretty straight forward.
post #8 of 8 (permalink) Old 12-22-2004, 06:11 PM
idanity's Avatar
idanity is an unknown quantity at this point
I'm about to take on this ordeal soon as well, mines a 325i conv.
nice advice dirty tool, the spring test is very easy, and your right, the driver side feels like the wheels not even spinning, yet the passenger side(same symptoms of the 1st thread) and the spring has a slight vibration...
all in all i phoned around and some suggested i replace the strut w/hub assembly.
seemed to take 15min. to remove at the junkyard, ill let ya know what happens going back in.
member of the <span style='color
range'>3 pedals club</span>
range'>195,000+ mile club</span>
<span style='color:red'> its the ones who cant even drive slow that think i cant drive better fast..</span>
idanity is offline
Need info on the german made E19 wheel @large 1,6,7,8 - Series and Mini Cooper 0 09-12-2005 10:48 PM
Ahh..... The Age Old Question liltrig99 3-Series (E36) 11 08-04-2005 02:29 AM
Wheel Bearing Info nookatee 3-Series (E36) 2 07-08-2005 01:08 AM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
18" wheel offset info malc e 5-Series (E12,E28, E34, E39, E60) 1 12-31-2003 09:34 AM
