backfire and loss of power - BMW Forum - BimmerWerkz.com
Old 02-22-2009, 06:13 PM   #1 (permalink)
nadeemkhan is on a distinguished road
my 91 525i backfires and looses power on fast accelerations, uphill and around 50/55 mph. I had complete tuneup done with brakes and roter changed but no improvement...
nadeemkhan is offline   Reply With Quote
Old 02-22-2009, 07:08 PM   #2 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
I would start by checking for leaks around the MAF Sensor, mainly around the intake boot, they are prone to dry out & crack, causing leaks! Also, I would try cleaning the MAF Sensor.....
http://i70.photobucket.com/albums/i9...s/b338c8e0.jpg
e36-tech.com | CLEANING YOUR Mass Air Flow Sensor DIY
johnny,
Old 02-22-2009, 11:18 PM   #3 (permalink)
Thank you Jonny! that's lots of help especialy with pictures... I'll try it this weekend.
Old 02-23-2009, 09:44 PM   #4 (permalink)
Car: 92 E34, 99 E38 (goner), 90 E34
emiliomax is on a distinguished road
That is a cool idea Johnny. I'm also gonna try it tomorrow. I've been getting some misfires and hesitation when I first put it in gear. Thanks
emiliomax is offline   Reply With Quote
Old 03-26-2009, 01:07 AM   #5 (permalink)
...so I took it to a mechanic who found a bad coil and a bad hose. Both have been replaced. The car starts but runs very poorly feeling it is going to run out of power. Mechanic thinks it is the feul pump... Tomorrow, he will test the pressure and let me know for sure if it is the pump...
Old 03-26-2009, 01:19 AM   #6 (permalink)
oldschool93 is on a distinguished road
hey, try cleaning the ICV, its a common problem with an easy solution
Cheeers
oldschool93 is offline   Reply With Quote
Old 03-26-2009, 12:38 PM   #7 (permalink)
What is an ICV and where do I find it? Last summer it had a complete tuneup and the fuel filter was replaced...
Old 03-26-2009, 02:57 PM   #8 (permalink)
Idle control valve, I am not sure where you would find it on your engine, here is a thread, there is no pics but thats what i followed to clean mine and i did fine. ICV cleaning instructions for E39 - Bimmerforums - The Ultimate BMW Forum
this one shows more pics but less explanation:
ICV Removal
i hope it works
Cheeers
Old 03-26-2009, 10:11 PM   #9 (permalink)
Thanks OldSchool! I'll try it when I get the car back this weekend. The mechanic couldn't test the fuel pump and he has given up after trying the following things:
Pull/replace spark plugs
Pull/Bench test coil packs and replaced 1
Checked wires, vacume hoses, MAF, intake for leaks/shorts
R&R (not sure what it means)
Clean MAF
Replaced air filter
Rewired ground to 6 coil packs
Chcked individual wires to coil packs and injectors
R&R IAC hose
Old 03-26-2009, 10:50 PM   #10 (permalink)
oh wow. you trust this mechanic? i cant belive he woudlnt think of this. give it a try and let me know how it goes. good luck.
Cheeers
Loss of power eduardope 3-Series (E36) 20 09-26-2007 07:18 PM
power loss! bimmerguy82 3-Series (E36) 7 02-27-2007 11:59 PM
Power LOSS skawful 3-Series (E36) 4 08-09-2004 07:56 AM
Loss of power flipsgonetopless 3-Series (E21, E30) 10 08-05-2004 02:41 PM
Power Loss BlackEye 5-Series (E12,E28, E34, E39, E60) 6 08-21-2003 03:28 PM
