Atf Leak - BMW Forum - BimmerWerkz.com
Old 03-04-2005, 06:53 AM   #1 (permalink)
fdeee is an unknown quantity at this point
Hi, I was wondering if anybody has ever had this problem. I have noticed a burning smell in my car the last few months and looked under the hood for a sign of a leak and found that the ATF reservoir seems wet and that it might be leaking, it looks like underneath the resevoir it is wet from a dripping of atf fliuid. Now tha my 528 has over 100,00 miles on little things seem to be croping up.javascriptticon('')
fdeee is offline   Reply With Quote
Old 03-04-2005, 07:12 PM   #2 (permalink)
billB's Avatar
If your reservior is leaking a small hose under a clamp connects to the buttom of your power steering fluid reservior..check both the tip of the hose and clamp....if in doubt disconnect it, cut a small piece if the tip is cracked, replace clamp, reconnect but don't over tighten (plastic!) then refill with fresh ATF.
regards
billb
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 08:00 AM
Oil Leak htp.bmw 3-Series (E21, E30) 6 09-07-2005 12:15 AM
A Slight Leak mikester328 3-Series (E36) 1 01-06-2005 11:20 AM
Oil leak... Regnout 3-Series (E36) 21 11-07-2004 09:06 PM
faster leak when cold. dubumb 5-Series (E12,E28, E34, E39, E60) 12 02-02-2004 09:42 PM
