ASC question - BMW Forum - BimmerWerkz.com
Old 09-03-2004, 01:55 PM   #1 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
I was passing a tractor on this country road, fairly straight, smooth...maybe a little gravel.
When I went to pass him i had my ASC off. while I was passing him I noticed my asc light blinking.
What does this mean? is this some sort of automated anti skid thing that keeps you steady even when you have it off?
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline   Reply With Quote
Old 09-03-2004, 04:59 PM   #2 (permalink)
Just did it again around a corner (I took it a little fast)
What is the meaning of this?
Old 09-03-2004, 09:39 PM   #3 (permalink)
billB's Avatar
I think you just witnessed what All BMW'S with slip control systems do. They have 4 wheel speed sensors which monitor each wheels speed of rotation with a high accuracy. The system control unit uses this information to calculate a vehicle speed. In this way it detects wheel speed variation. A common problem : If the inputs vary from each other by a certain amount, the control unit is not able to do the calculation reliably (plausibility fault) and takes its self off-line as a safety precaution(fail-safe).This can be because the wheels and tires are non-approved partsand therefore do not agree with the system.SOLUTION: Make sure the vehicle is fitted with BMW approved wheels and tires. Then do further diagnostic testing to check if fault is resolved.
In sum: it is a normal reaction on gravel and slippery roads providing you have the proper tires and wheels.
Old 09-03-2004, 10:07 PM   #4 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
d3ity,
In your case no need to worry... It's only telling you that the
system is actively regulating drive torque in response to the driving
conditions.... If it stays on all the time, then you have a problem.
LOS
Old 09-03-2004, 10:33 PM   #5 (permalink)
badass, i just wasnt sure whether there was a problem, or my car is just a fucking phd
by the way, wheres the magic list o tires kept?
Old 09-04-2004, 02:20 PM   #6 (permalink)
billB's Avatar
d3ity and LOS
open the drivers door look to the right for a black sticker with silver lettering on or open your manual on page.........wooooooo come on d3ity you know better than that.
regards
bill
Old 09-04-2004, 04:27 PM   #7 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
this is a bit off topic but...
in ur sig d3ity, did u have to modify a bit to get ur highs and ur fogs to be on at the same time?
Old 09-04-2004, 04:32 PM   #8 (permalink)
billB's Avatar
whatever the case may be: IT IS ILLEGAL to have all fours on...so beware of tickets!!
Old 09-04-2004, 09:48 PM   #9 (permalink)
All 6 actually.
Yes, i did some modification to get it to work... It happened completley accidentally.
Cut your fog light wires... rewire them backwards, enjoy.
I posted about this, the only problems are... you cant use the switch inside...and you cant turn them off.
ASC and pulsating brakes beeben 5-Series (E12,E28, E34, E39, E60) 2 10-09-2005 10:54 PM
318is scorpion exhaust question alex_318is 3-Series (E36) 4 09-13-2005 01:47 PM
323i Single Pipe Exhaust Question vindude69 3-Series (E36) 2 03-22-2005 10:57 AM
Just got my 320i: Small question harpax 3-Series (E46, E90) 18 06-17-2004 04:24 PM
info center in the gauge cluster question audiosolstice 1,6,7,8 - Series and Mini Cooper 3 04-30-2004 02:58 AM
