Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 05-25-2004, 09:22 PM   #1 (permalink)
Photos: 0
Franks528i is an unknown quantity at this point
Okay a week ago the asc light turned on and wouldnt turn off, the next time i drove it it was off then when I got onto the tollway it turned on and has been on since (about 5 days). the car drives okay. i have no check engine lights. What are the possible problems. could it be a variance in tire pressure (high hopes), bad wheel bearing or sensor? please help
<span style='font-size:14pt;line-height:100%'><span style='font-family:Geneva'>Frank</span></span>
<span style='font-family:Optima'>97 528i </span>
Euro' Clear Angel Eyes
Celis tail lights
OEM M5 Wheels
<span style='color:yellow'>Slow ass engine.</span>
Franks528i is offline   Reply With Quote
Old 05-26-2004, 12:38 AM   #2 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Photos: 0
Wow an ASC light? wtf? lol srry ill probably get it if you take it out of the acronym form, im just really lost right now.
Old 05-26-2004, 01:24 AM   #3 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Photos: 1
It means you have no traction and the problem could be anything from brakes to suspension issues.
LOS
Old 05-27-2004, 11:25 PM   #4 (permalink)
Photos: 0
well the last few days, probably more, my front struts feel like they might be going out. could this cause it? how would bad brakes cause this light to come on?
Celis tail lights
OEM M5 Wheels
Old 05-28-2004, 10:15 AM   #5 (permalink)
LOS
LOS's Avatar
Photos: 1
Sorry, is not really the pads, could be the fluid. If you just flushed it and have a leak or air bubles in the system, etc... Check the fuses as well and clean the suspension components. lookf for anything that is loose in the suspension.
struts??? if we're talking about traction... maybe that's it, but the whole front end of the car would feels loose (a floating feeling when you make turns). I'll keep reading the repair manual...
LOS
Old 05-28-2004, 06:44 PM   #6 (permalink)
Photos: 0
thank you for your help.
Celis tail lights
OEM M5 Wheels
Old 05-29-2004, 02:08 PM   #7 (permalink)
Photos: 0
02bmw540isilvergreynav is an unknown quantity at this point
Frank, I am sorry to tell you it is your transmission slipping. I have a 97 with the same problem right now i have been to busy to deal with. I just went ahead and bought a new car.
I am gettng it fixed to trade in for my wife's new car instead so I am having a used tranni put in for 2000. rebuilt would be 3700 according to the local guy. I am having one shipped to aamco since I am not keeping the car. I did notice my fluid was low so when I get a chance I will try that first but I don't think it is going to help. I think we are both screwed! I will let you know if I find different.
02bmw540isilvergreynav is offline   Reply With Quote
Old 05-30-2004, 01:04 PM   #8 (permalink)
Photos: 0
thanks for the potentially bad news. i really hope thats not my case.
Celis tail lights
OEM M5 Wheels
Old 05-30-2004, 01:11 PM   #9 (permalink)
TMac325is's Avatar
Photos: 0
it is possible to turn the ASC on and off manually isnt it?
correct me if im wrong, but on my 3 series its the little button infront of the shifter.
does anybody know if there is much of a difference if you turn it off and drive around?
Old 05-30-2004, 10:47 PM   #10 (permalink)
EXtech's Avatar
Photos: 0
Typical problems: faulty wheel speed sensor, faulty ASC control unit or in the rare case mentioned above, a transmission problem. Generally if the transmission is failing you will have noticeable slippage and/or usually trans program fault codes. There is a small possibility if it's a transmission issue that it is the output speed sensor inside the trans. It's more likely that you have one of the other two issues occuring (faulty ASC control unit or wheelspeed sensor). Take it to your local shop and have the fault codes checked, this is the only way to know for sure. I wouldn't procrastinate though. Good Luck !!
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 05-31-2004, 08:14 PM   #11 (permalink)
Photos: 0
thank you again. what does it cost to have the car scanned at a dealer? i can fix it myself but I just need to know what it is.
Thank you
Celis tail lights
OEM M5 Wheels
Old 06-01-2004, 12:44 AM   #12 (permalink)
LOS
LOS's Avatar
Photos: 1
I'm sorry it too so long to get back to you... EXTECH is right on the money on his/her reply!! And like he/she said, the only way to know it's to take it to the dealer and read the codes.... which should tell you what the problem is. Hopefully it will only be a sensor... Good luck... The dealers here in L.A charge around $125 just to look at the car... It all depends where you live
P.S KEEP US INFORM ON YOUR FINDINGS... IT WILL HELP THE REST OF US.
LOS
Old 02-24-2005, 08:20 AM   #13 (permalink)
machinehead's Avatar
Photos: 0
machinehead is an unknown quantity at this point
Send a message via MSN to machinehead Send a message via Yahoo to machinehead
Was there ever a fix/outcome on this?
The ASC light has been on since I bought my 525 e34 last August. ABS works fine, as does the speedo. The actuator cable is not broken and is adjusted per spec. and the throttle position sensor has been replaced, as has brake fluid & the pads are fine, all tyres even, same size/brand.
When engine is first started (not in gear) the light is off and can be turned on and off via the ASC button. Now, give the engine a blip of the throttle (over 1,100 rpm) and the light comes on and stays on - because of this I cannot see its an ABS sensor, and must be a faultly ASC unit as far as I can deduce.
Any thoughts? Are these simple to replace? Is a 2nd hand one likely to be good or are the units prone to failure?
<span style='color:blue'><span style='font-size:9pt;line-height:100%'><span style='font-family:Arial'>because life's too short not to..........</span></span></span>
machinehead is offline   Reply With Quote
Old 02-24-2005, 12:39 PM   #14 (permalink)
Photos: 0
BeelZibub is an unknown quantity at this point
ASC+TRACTION works off of the ABS sensors on the rear wheels, hence if an ABS sensor gets damaged/fails or is simply disconnected your ASC light will usually come on - But as said above getting a code scan is the best way to go.
BeelZibub is offline   Reply With Quote
Old 02-24-2005, 12:53 PM   #15 (permalink)
k2c69n's Avatar
Photos: 0
k2c69n is an unknown quantity at this point
Yeah , i too have the same probably it comes and goes periodically.. I am going to take it to get it fixed once the weather gets a bit nicer.. I know mine doesnt have to do with the transmission at all.. mine works perfectly.. but those abs sensors are pretty pricey.
*If your not living on the edge your taking up too much space*
'98 328is
k2c69n is offline   Reply With Quote
vB code is On
"help! I Want Better Headlights On My 3er!" jlevi 3-Series (E46, E90) 43 09-25-2008 08:34 PM
Unusual light problem jmalkowich 3-Series (E46, E90) 2 11-11-2005 09:11 PM
Abs/asc Light On 2000 523/525 Avatar1 5-Series (E12,E28, E34, E39, E60) 2 10-16-2004 09:49 AM
COMPUTER CHECK - TAIL LIGHT FAILURE?!?? kraze0g 3-Series (E36) 3 06-25-2004 11:30 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
