Asc Lamp - BMW Forum - BimmerWerkz.com
Old 05-24-2005, 08:35 PM   #1 (permalink)
Rkhoubian is an unknown quantity at this point
Hi guys,
I have a problem. I have ASC lamp on all the time and my ASC button not able to take it off. Does any body know what is wrong?
Thanks
Rkhoubian is offline   Reply With Quote
Old 05-26-2005, 06:33 PM   #2 (permalink)
Originally posted by Rkhoubian@May 24 2005, 08:35 PM
Hi guys,
Thanks
[snapback]347600[/snapback]
That is it,
I checked this issue and it was cable $ 20 CAD cost and easy to replace
Rob
Old 05-28-2005, 07:41 AM   #3 (permalink)
machinehead's Avatar
machinehead is an unknown quantity at this point
Send a message via MSN to machinehead Send a message via Yahoo to machinehead
Hi, I've had this issue since last year (1993 E34)! ghead
don't know what car you have though.
The cable's a start. if you read my problem, the ABS, speedo and cruise all worked ok, if they don't then I would think that a wheel sensor is likely to be the issue. Have a read
http://www.bimmerwerkz.com/forum/index.php...opic=13433&st=0
and see if anything helps - Mine turned out to be simple, after a lot of expense cleaning MAF (and killing it), changing the throttle position sensor (which is what the original diagnostic said the problem was!), etc……
regards
<span style='color:blue'><span style='font-size:9pt;line-height:100%'><span style='font-family:Arial'>because life's too short not to..........</span></span></span>
machinehead is offline   Reply With Quote
ASC and pulsating brakes beeben 5-Series (E12,E28, E34, E39, E60) 2 10-09-2005 10:54 PM
Head Lamp: 2004 325i Versus 325ci postrio 3-Series (E46, E90) 1 11-06-2004 09:46 PM
obc lamp replacement lamia1 3-Series (E36) 2 05-02-2004 02:37 AM
brake lamp is still on HELP!!! pherbolario 5-Series (E12,E28, E34, E39, E60) 6 02-04-2004 09:33 AM
fog lamp help cbrent M-Series (M1, M3, M5, M6) 1 12-21-2003 06:19 PM
