Asc & Eml Lights Come On Intermittently On 99 528i - BMW Forum - BimmerWerkz.com
Old 04-10-2005, 09:35 PM   #1 (permalink)
onemoz is an unknown quantity at this point
Send a message via Yahoo to onemoz
Hello everyone I just purchased a 99 528I. everthing was going great until Both the ASC & EML light came own when i was driving. I've had the car for about 2 weeks and its happened twice usualy when i'm driving at very low speeds for example at a grocery store parking lot.
What happens is that once the lights go one i have a loss of power but if I punch it the lights both go off and the car goes back to normal.
Has anyone had the same problem if so what are some things I can do to fix this ?
onemoz is offline   Reply With Quote
Old 05-27-2008, 06:41 AM   #2 (permalink)
billos is on a distinguished road
Hi I Have The Same Problem Here!!!have You Fixed It ????perhaps You Can Help Me...
billos is offline   Reply With Quote
Old 05-28-2008, 09:52 AM   #3 (permalink)
MeanM50's Avatar
Car: 1992 525i NV M50...lightly mod'd
MeanM50 is on a distinguished road
Holy thread from the dead Batman! The original post is three years old.
MeanM50 is offline   Reply With Quote
Old 06-14-2008, 09:31 AM   #4 (permalink)
Car: 85 325e 90 525I '96 328i
pinnaclebass is on a distinguished road
Send a message via AIM to pinnaclebass Send a message via Yahoo to pinnaclebass
these keep popping up back into exsistence. but i did have a question about what the ASC and EML lights MEAN?
pinnaclebass is offline   Reply With Quote
Old 06-14-2008, 10:17 PM   #5 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
EML = Electronic Throttle Control System(why EML beats me)
ASC/DSC = refers to traction control system
Here's a primer on EML and why ASC/DSC lights up along with it :
The Electronic Throttle Control System (EML) regulates the operation of the throttle valve(s).
The scope of EML design on BMW engines provides:
• Throttle valve positioning for optimum starting
• Precise idle speed regulation without the use of an external idle control valve/circuit
• Progressive throttle opening curves matched to the driving program (with EGS/AGS interface)
• Cruise control operation without additional control modules and linkages
• Automatic synchronization of the throttles (airflow balancing) for two independent banks,
throughout the entire engine speed range (M70, S70, M73 engines only)
• Intake air volume control for ASC/DSC (Automatic Slip Control/Directional Stability Control)
systems
• Maximum road speed limiting
• Emergency “Failsafe” operation in the event of component failures
The EML control module is a link in the total scope of Engine Management Control. The EML
is interfaced with other control modules to complete the management system, which includes:
• ECM(s) - Except E46 (EML integrated in MS42.0 ECM)
• EGS/AGS
• ABS/ASC
The main components of the EML system are:
• Accelerator pedal position sensor (PWG)
• Accelerator pedal position sensor (driver’s wish sensor - integrated in throttle housing,
E46 MS42.0)
• Throttle valve assembly/assemblies with electronic control motor(s) - DK/MDK
• EML control module (MS42.0 ECM - E46)
*** see the inter-relation??? :-)
How To Tell Options With Vin? cm70man 5-Series (E12,E28, E34, E39, E60) 18 12-31-2010 01:05 AM
Need Carfax Report, Please Help F U Have Carfax Ac ozbmw 5-Series (E12,E28, E34, E39, E60) 2 05-11-2005 10:58 AM
99 528i (passenger Side Fog Lights) tasbmw 5-Series (E12,E28, E34, E39, E60) 1 02-21-2005 08:06 PM
Carfax Please: Wbadd632xwbw44671 cpuken 5-Series (E12,E28, E34, E39, E60) 3 12-03-2004 08:04 PM
