Anyone use Nex coilovers? - BMW Forum - BimmerWerkz.com
Old 08-28-2007, 11:59 PM   #1 (permalink)
E39Dream's Avatar
Car: 97 540i
E39Dream is on a distinguished road
I just bought a set for 500 brand new for my 97 540. They are the SS I think. Bronze body with Black springs. Anyway adjustable from 1.5 to 3. I want to slam it so that should take care of that issue. But I was wondering about their life. Oh yeah and does anyone know if I have to use the top shock mounts from a 528?
For all of your BMW used parts needs Email me at Brandon@Speedwayparts.net
E39Dream is offline   Reply With Quote
Old 08-29-2007, 12:59 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
You are going to need some sort of upper camber/caster plate to work with the coil-over type spring because the stock upper spring hat will not work on a 2.5"/60mm coil-over spring. Also, if you use a coil-over setup on stock struts don't expect them to last more than a month or two before the seals give out. You will need some sort of sport strut designed for cars lowered more than 1" like Koni SA's or Bilstein Sports. Once the car is lowered it will need an alignment because the toe settings will be way off and cause the tires to wear unevenly.
My M50 Powered E30 Page
Old 08-29-2007, 01:11 PM   #3 (permalink)
E39Dream's Avatar
Car: 97 540i
These are full bosy coilovers. They come with springs and strut.
E46 M3 KW V3 Coilovers Height, Rebound and Dampening Adjustable Rsquad911 Aftermarket Parts 1 08-04-2007 09:31 PM
Coilovers guywithblack88e30 3-Series (E21, E30) 2 10-29-2004 08:40 PM
springs vs coilovers socalguy 3-Series (E36) 9 04-15-2004 12:12 AM
H&R Coilovers asiangear 3-Series (E46, E90) 4 03-01-2004 11:10 PM
Coilovers on, found something else cool out! Scarface 3-Series (E36) 14 12-08-2003 09:31 AM
