Possibly, if you've got something solid the other side of it to drive against, could do what I've done in the past to pull bushes out of... something on the front of a 205, I think it was, can't remember exactly what.
Use a long threaded bar (or an old head bolt or similar), a suitably sized washer, and three nuts.
Drill through the bush, run the rod through, put the washer on, put a nut behind it, and then turn the bar, holding the nut behind the bush in place.
The two other nuts, if you're using simply a long threaded bar, lock one against the other on the end of the rod, and then use a socket to turn the rod.
The alternative to get the mountings out It is not easy (but it can be done)
1: A friend with a hoist in his shed
2 A right angled air powered drill (also belong friend)
3, A hacksaw blade in a handle (from another friend)
4 A small cold chisel (mine)
5 A big hammer (also mine. that's the kind of mechanic I am)
Drill out as much of the rubber as possible on one side
Cut out the remaining with a coarse hacksaw (join the holes together)
Cut down the aluminium casing with the hacksaw (this is the frustrating bit)
use the small chisel and big hammer to bend the casing away from the housing of the axle carrier
Pull out the mangled bit
Also made a tool to pull the mount back in. More on that later
__________________ My daily is a Mitsubishi HSGR (but I wouldn't mind an e34 525i)
You also need to take off the rear seat belt mounts or you can't get the bolt out past the plastic surround
The centres fell out of the mounts after we got them unstuck from the body
We also did the pitman arms and replaced the rear brake shoes
This was spread over a number of days as it was done between work and off days. On the hoist Sunday pm, Started Monday, worked Tuesday finished all jobs Wednesday.
A goodly couple of hours were spent Monday making a tool to push the mounts back in Pics later. Using this only took about ten minutes to set up and screw the mounts in using a couple of drops of detergent in 500 mils of water for lubrication.
The mounts have external grooves which correspond to a couple of (almost) unseen dimples in the housing
The car now does not clunk and does not self steer on rough bits of road (of which there are plenty down here)
Next job is front control arms (next week)
