Anti-trap function deactivated - BMW Forum - BimmerWerkz.com
Old 07-16-2011, 04:45 AM   #1 (permalink)
fov001 is on a distinguished road
Question Anti-trap function deactivated
Any had this problem? "Anti-trap function deactivated"
Also, shoudl the "service engine soon" light be on when the switch is open? meaning I turn the key once but the car is not on.
Engine Service Soon message
When I turn the engine on, the "service engine soon" message disappears but still I can see the excamation point from "Anti-trap function deactivate"
Thank You all!!
fov001 is offline   Reply With Quote
Old 07-19-2011, 11:08 AM   #2 (permalink)
haley67 is on a distinguished road
I have, it just happened to me. All I had to do was start the car, press and hold the toggle switch down (for whichever window isn't working properly) for five seconds. Then pull the switch up and hold it for 5 seconds after the window has reached the top. You have to do all this from the drivers control panel, but that should reset your issue. If you aren't sure which window is malfunctioning, roll all of them down and whichever one, or ones, won't roll up with the one touch is the window that needs to be fixed.
haley67 is offline   Reply With Quote
Old 07-19-2011, 11:25 AM   #3 (permalink)
Thanks for your response. I did get an answer in another forum. To diagnose the issue I had to check which window did not rolled all the way down automatically, Then I held down the window button from that seat for 17 seconds, then up, then while holding it up, the window will go down and up automatically. After this turning the car off then on it resets the message.
Thanks for your help!!
Old 07-19-2011, 12:27 PM   #4 (permalink)
Not a problem at all. Glad you got it fixed!
Old 07-19-2011, 04:22 PM   #5 (permalink)
By any chance, do you know if the "engine service soon" message should be on when the switch is on??
TV Function on E90 tboury 3-Series (E46, E90) 0 07-22-2008 11:58 PM
Airbag Deactivated with Passenger Miami545 5-Series (E12,E28, E34, E39, E60) 5 06-21-2004 08:15 PM
Speed Trap Ahead!!! jaavaajoe 3-Series (E46, E90) 3 04-19-2004 08:41 AM
