Antenna, Aftermarket Radio And Poor Reception - BMW Forum - BimmerWerkz.com
Old 01-18-2005, 08:30 PM   #1 (permalink)
ben_t is an unknown quantity at this point
I have a non-BMW radio and the reception is really poor.
Because the three antennas are in the rear window and whilst the OEM radio is meant to select a combination of the three, my current radio doesn't select any of them. It just stays on one of them.
Is there a way to wire it so that the radio uses all three antennas, or is better to install an external antenna?
ben_t is offline   Reply With Quote
Old 01-19-2005, 01:48 PM   #2 (permalink)
maci4life is an unknown quantity at this point
i didn't know they had 3 antennas. My aftermarket doesn't catch am at all, fm is decent, but i mainly listen to cd anyways.
maci4life is offline   Reply With Quote
Old 01-19-2005, 09:54 PM   #3 (permalink)
Moderator
Dirty_Tool's Avatar
What year is your 535 and what radio system does it have in it? Does it have the top hi fi system with tweeters in the front doors up in the corner near the side view mirrors? By memory there really should be only 1 coax going into the antenna amplifier from the deck, some models did have a mini coax as well to 2 total. I believe the antenna amplifier does the distributing throughout the grid in the rear window. Give me the specific info and Ill look into it for you.
DT
DT
Old 01-20-2005, 04:33 PM   #4 (permalink)
It's a 1998 model. I think it has a standard radio system. There are no tweeters in the door.
Is it possible to "tell/force" the antenna amplifier to use the entire antenna grid?
