Another Radiator Failure - 70K miles - BMW Forum - BimmerWerkz.com
Old 01-20-2012, 11:32 AM   #1 (permalink)
Car: 1995 525i Calypso Red
Pete Lech is on a distinguished road
Unhappy Another Radiator Failure - 70K miles
The Germans are great with metal, but not so good with plastics, I guess.
1. My first radiator failed at 10 years, 92K miles. The outlet neck broke off, losing all the coolant. My wife was driving on the freeway and didn't notice the steam out the back of the car until flagged down. (No warning lights illuminated). Cost $2K to rebuild the warped head and replace the radiator.
2. The second just failed with a cracked side tank (not the expansion tank) at 155K miles and 7-1/2 years.
At least I caught it before any damage was done. Found a source for the OEM replacement @ $170. delivered.
It seems so unnecessary - if they just had made it right in the first place.
Thanks for letting me rant.
Pete Lech is offline   Reply With Quote
Old 01-21-2012, 08:32 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Thanks for the rant !!
There are aftermarket rads... Full aluminium ones (zero plastic)
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 01-21-2012, 10:39 AM   #3 (permalink)
jimmythepie's Avatar
Car: 98,328i
Ranters are particularly welcome on this site.
jimmythepie is offline   Reply With Quote
Old 01-23-2012, 05:34 AM   #4 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
This is what I used to prevent the problems that you experienced, not cheap, bit no more risk of repeating your troubles.
Zionsville Autosport: BMW E39 - E38 Super Duty Cooling Kit
Riding in style
Old 01-23-2012, 10:29 AM   #5 (permalink)
The Germans are great with metal, but not so good with plastics, I guess....
Well, apologies to the makers of the radiator for casting aspersions on them. While waiting for the new radiator to arrive, I decided to take apart the old one, out of curiosity and so I could recycle the aluminum core. I discovered that there is a rectangular rubber seal between the plastic end tank, which is crimped to the radiator core. The tank showed no signs of any cracking. I believe that in installing the expansion tank, which was very tight and required a bit of effort with a rubber mallet, that I disturbed the seal, leading to the leak. The expansion tank also did not show any cracks either, when I finally got it out.
My current thinking is that it was really the o-rings on the radiator cap that were the cause of the leak, and my failure to apply the simplest solution let to a lot of work and expense for myself.
Radiator Swap From 87 325i To Later Radiator From 89 325i TOMMYSPANNER 3-Series (E21, E30) 0 04-10-2010 12:50 PM
AC failure rashid 5-Series (E12,E28, E34, E39, E60) 3 07-16-2009 08:28 PM
Seat belt latch failure at 22000 miles bmw325-2001 3-Series (E46, E90) 4 10-26-2005 03:00 PM
Warning Signs Of Radiator/pump Failure? Eric S. 5-Series (E12,E28, E34, E39, E60) 4 12-18-2004 09:48 PM
