Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 08-14-2005, 12:51 PM   #1 (permalink)
Photos: 0
ajt3nc is an unknown quantity at this point
I bought an 89 525 that has gauge issues. None of the gauges or odometer work.
The idiot lights and turn signals are functioning.
I checked the underhood fuse box and they are all intact. There is a open relay socket . If you are on the drivers side the open socket is on the closest row on the left. Does the relay have anything to do with this or do I need a new cluster?
Thanks,
AJ
ajt3nc is offline   Reply With Quote
Old 08-15-2005, 02:22 AM   #2 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3 | 1983 Yamaha something
Photos: 0
Sounds liek a problem with your capacitors. These generally cause your gauges to stop function. Is all your lighting still working?
Old 08-15-2005, 01:53 PM   #3 (permalink)
To the left ...
Torque's Avatar
Car: '90 535im
Photos: 0
Send a message via AIM to Torque Send a message via MSN to Torque
Check here:
http://www.bmwe34.net/e34main/maintenance/.../capacitors.htm
and
http://www.bimmernut.com/%7Ebillr/images/a...agAndBulbs.html
Old 08-19-2005, 11:38 AM   #4 (permalink)
Photos: 0
mycarblows is an unknown quantity at this point
Send a message via AIM to mycarblows Send a message via Yahoo to mycarblows
Thanks,
AJ
[snapback]369547[/snapback]
you should pull out the gauge cluster and make sure your connections are all in the back nice and tight. i have an 85 535i and i once rattled the connections loose. Just hope you dont have to replace the whole cluster. it was 100 bucks at the nearest junkyard when i had to go get one to rob the speedo for my car.
my car blows
<img src='http://tinypic.com/f1jihw.jpg' border='0' alt='user posted image' />
member of the "16 years old and i drive a BMW club"
member of the "3 pedal club"
mycarblows is offline   Reply With Quote
Old 08-21-2005, 09:39 PM   #5 (permalink)
Photos: 0
It was the board in the cluster. I found a place on ebay that sells reman boards for $140.
It worked perfectly, and the service indicator (?) came to life. Now I get to replace the coolant l
level sensor.
Old 09-18-2005, 12:47 PM   #6 (permalink)
Photos: 0
davidvh2 is on a distinguished road
Another Gauge Cluster Question
I've noted the very detailed description of how to remove the instrument cluster on the model under discussion but (a) is this the same as far as you know, on an E39 2000 530 & (b) does one have to have the computer reset in some way after disconnecting the cluster from the wiring? My car does have the computer on board & all I want to do, is replace (probably) just one lamp/bulb to backlight the display (area where distance is shown, is dull). I've even wondered if it's possible to change the faulty bulb without actually disconnecting the wiring harness. Any ideas most welcome & Yes, I'm a new guy in here so a Big Hi to all.
David
davidvh2 is offline   Reply With Quote
Old 09-24-2005, 07:19 PM   #7 (permalink)
Photos: 0
1_bad_5 is on a distinguished road
I am not sure about a 2000, but on the E34 you are able to replace the bulbs without anything reseting
1_bad_5 is offline   Reply With Quote
vB code is On
Diy: Gauge Cluster Light Delete ///M Power 5-Series (E12,E28, E34, E39, E60) 11 08-10-2005 10:23 AM
Removing Gauge Cluster exjarhead328 3-Series (E46, E90) 1 03-10-2005 03:22 PM
Gauge Cluster Light Burnt Out Silverstreak 3-Series (E36) 3 02-19-2005 01:23 AM
info center in the gauge cluster question audiosolstice 7-Series 3 04-30-2004 03:58 AM
Gauge Cluster Problem BMWGuy325i 3-Series (E36) 4 04-25-2004 11:34 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
