ALTERNATOR! help! - BMW Forum - BimmerWerkz.com
Old 03-02-2004, 07:23 PM   #1 (permalink)
M5power is an unknown quantity at this point
well i knew very easily my belt came loose when i heard it squealing like crazy one morning, i tried to tighten it with the bolt and everything. well i come to find out the Alternator bracket that mounts onto the engine is screwed up badly, the teeth on there are almost all broken off . i also come to find out that my nut that has the teeth in it that makes it easy to raise the alternator up for tightening, those teeth are broken off, exept for a few. this is a 1985 BMW 528E, can anyone help me out on where i can find these parts because there are no real close part stores for me to get these and expet the junk yard, any online siteS? thanks!
<img src='http://www.tehseen.net/david.jpg' border='0' alt='user posted image' />
The b0x that r0x
M5power is offline   Reply With Quote
Old 03-02-2004, 08:03 PM   #2 (permalink)
njtech is an unknown quantity at this point
You can tension the belt temporarily using a prybar/ lever, until you find the right parts. I may have an extra bolt at the shop, I will check and email ou tomorrow.
njtech is offline   Reply With Quote
Old 03-02-2004, 08:44 PM   #3 (permalink)
alrite thanks! the nut on there is so badly messed up, but yeah ima try to go to the junk yards tomorrow and see if they have one there. Lemme know! thanks
The b0x that r0x
Old 03-02-2004, 09:13 PM   #4 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
have you tried Bavarian Autosport ?
Old 03-06-2004, 12:07 AM   #5 (permalink)
while this topic is still open, how do you know when you have reached the correct belt tension?? thanks...
Old 03-06-2004, 11:24 AM   #6 (permalink)
yeah i fixed my problem and got a new bracket, how tight does it need to be? is having it too tight relly bad for it?
The b0x that r0x
Help! Help! Help! dvmotorsports 3-Series (E36) 6 06-02-2005 12:51 AM
Hello I Am A Noob, Help! Obiein808 3-Series (E36) 16 12-30-2004 06:26 PM
HELP! Radio PIN Connections HELP! acura_dude 3-Series (E21, E30) 2 06-26-2004 05:35 PM
Help! My a/c will not turn on! jroberts312 3-Series (E36) 7 05-28-2004 03:30 PM
2001-2003 M3 Steering. Need Help!? BMWPro77 3-Series (E46, E90) 6 01-31-2004 07:22 PM
